Vats
Old Dec 5, 2006 | 09:18 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
Vats
Hey, kinda new to tpi, learning a lot really quickly tho. I read on a site tpiparts.net, that the 89 tpi looks for the vats box...i have an 86 iroc no chip in key or anything like that. I also heard my car does have a vats box because it has cruise. so im just wondering if anyone knwos for sure, without me taking apart the dash, if i have a vats and if the 89 tpi would be happy with this older one?
oh the car originally came with the 305 4bbl carb, if that helps.
Old Dec 5, 2006 | 11:19 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your '86 car does not have VATS.
I dont understand what you mean by "if the '89 TPI would be happy with this older one?"
If you're trying to put an '89 TPI system on your car, then you will need a custom chip with the VATS in the chip turned off. That's it.
Old Dec 6, 2006 | 06:33 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
yeah I thought I was a DEE DEE DEE while reading the original post
Old Dec 6, 2006 | 08:32 PM
nascar2496's Avatar
Engine: 305 tpi
alright, well im just telling you what i was told, thus the whole point of the post was to see IF it was true, I didnt think it was but i have to check, i dont want some stupid box preventing my car from not starting.
so here is another question, is it possible to have the cruise working?
Old Dec 6, 2006 | 09:01 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Vats is completely seperate from cruise control. Like Kevin said you will have to get a custom chip burned to work without vats and your cruise control should work the same as long as you do the proper connections when you put in TPI.
Old Dec 7, 2006 | 09:14 AM
nascar2496's Avatar
Engine: 305 tpi
ok thank you for the info.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
