Speed Density???
Old Dec 9, 2006 | 11:26 AM
91 Formula's Avatar
Car: 1991 Formula T/A
Engine: 415ci stroker-626rwhp 636flbs
Transmission: 5-speed
Axle/Gears: 4.56 posi
Speed Density???
What is speed density? Can ne of you tell me what it is and how to do free mods on a 91 Formula LB9 305 TPI
Old Dec 9, 2006 | 09:02 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Speed density refers to the type of ECM the car uses to control the engine. The computer in the 90-93 f-bodies (yes the '93 4th gen is speed density too) uses the speed of the car and the density of the incoming air (based on vacuum in the engine) to calculate the amount of fuel to squirt into the engine. The 85-89 f-bodies, as well as the 94-02 4th gens use a MAF (mass-air flow) sensor to calculate the amount of incoming air to determine the amount of fuel the engine needs. Speed density is also called a MAP system (manifold absolute pressure), because it uses a MAP sensor to measure the amount of vacuum in the engine, and how much of a load the engine has on it.
There are several tech articles on this website in the tech article section that deal with free mods and mods for beginners.
Old Dec 10, 2006 | 10:40 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Just to remove a possible confusion, the SPEED refers the ENGINE speed, not the speed of the car, hehe.
Since it is basically "guessing" the airflow from lookup tables, it doesn't handle large changes to engine airflow at all, unless you re-calibrate the PROM.
Some free (or cheap) mods:
Advance the timing a little
grind down EGR walls inside plenum (must remove plenum, and while you're at it, remove the base manifold and port it, or replace it).
K&N at a time when it's due for an air filter change anyway
Get into DIY PROM tuning, and lower the fan temps, calibrate the WOT fuel and spark, etc... Can be done pretty cheaply if you bargain shop for old chip burning stuff. If you start spending money on real parts, you won't regret being able to optimize the air/fuel and spark.
Buy performance replacement parts at a time when a part needs replacement - i.e. exhaust is totally worth it; good oils; spark plugs/wires
Make a cheapo high flow air filter duct and K&N on the end.
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RGB2015
Sep 20, 2015 09:26 PM
