fuel pressure regulator??
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
anyone know how to take the fuel meter cover off to replace the regulator?? i have torq bit sockets but t10 wont budge it... seems to have notch in middle where socket supposed to go??? any ideas??
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
sounds like you have what they call security torx or tamper proof torx bolts but are using a regular torx bit. a security torx type bit has a small hole in the middle of it.
they look like this,
http://www.wihatools.com/indexes/indxSecuritytorx.htm
Car: 87 Camaro IROC
http://www.jegs.com/webapp/wcs/store...15473_-1_11175
buy that, its adjustable and it comes with the tools and gaskets necessary.
Engine: 305 tpi
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Not 100% certain, but I'm fairly sure that won't solve his problem. I think the included bit with the Crane regulator is a regular torx bit, and will not have the hole in the center to loosen the factory bolts.
If you don't buy the correct tool, grab a small wrench, and place the torx bit over one of the regulator housing bolts. Whack the bit into the bolt 2 or 3 times. That will allow you to loosen the bolt with a standard torx bit.
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I bought a set of torx bits at the dollar store that had a hole in the middle and worked perfect! Go figure id find a set there?!
Engine: 305 tpi
because i do work for NAPA so i get parts cheap LOL thanks though bud
9192camaro
16
Feb 3, 2019 12:21 AM
