IAT mod
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
IAT mod
Well...I've been thinking about this for a while now. So, I have the holley stealthram and the IAT sensor is the coolant sensor that's metal and inside the plenum. So, one thing is its metal so once hot...it says hot. Two, its inside the plenum so the air reading isn't accurate. This is my thinking....howell-efi makes a IAT sensor mod that makes it possible to switch from the metal sensor to the LT1 plastic sensor. So, with that and moving it from the plenum to the air filter...I think the advantage will be a tremedous difference in a more stable AFR reading on restarts after the engine gets hot and WOT/cruise. So, what y'all think?
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
The aftermarket makes a kit for corvettes to do that,just call a corvette catalog place and they'll get you the wires with plugs.Eckler's is one,mid america,or corvette central anyone will be glad to sell you one.You just need to tell them if your plug is a mushroom shape or square.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If you truly understood how it worked and exactly what it does, you would not move it.
There is a lot more to it than simply placing it elsewhere in the airstream.
Check the actual code out or do some research on the prom board.
later
Jeremy
later
Jeremy
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I went with this sensor in the stock location https://www.thirdgen.org/forums/diy-...mp-sensor.html
If your car is a MAF then there really is no point to swaping since I believe it's only used for Egr control, on MAP cars might help but you would need to change some things in the chip.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yep exactly...however, in the Gen III engines, the IAT is mounted to the MAF. However, with the MAF...the IAT sensor is built into it but by moving it, they are seeing more consist air readings/consistant AFR/and they dropped a .1 in the 1/4 and their's ain't even in the plenum and getting heat soaked. Its more of a heat soak problem in my book then anything. So, this is more testing whether it will help the AFR stay consistant and air reading stay true than it being 50* at startup then after shutdown and restart after 30 mins at 210*.
Car: Faster
Engine: Than
Transmission: You!
What would you have to change in the chip?? The only thing I could think of is maybe some small tweaks to VE and PE. Besides that, am I missing something?
Car: 89 GTA
Good post on it here
https://www.thirdgen.org/forums/diy-...?highlight=iat
https://www.thirdgen.org/forums/diy-...t-weather.html
Car: 1991 Z28
Engine: SBC
tpiparts.net has 1...i bought it for my car.
Well on street tires i went 14.2 then 13.9 then 13.8. Before i couldnt get better then a 14.2. I installed that piece a day before i went to the track. My sixty foot on the 14.2 was a 2.261 and my sixty for the 13.8 was a 2.13. My mph didnt change much...100.15 for the 14.2, 100.64 for the 13.8
so did it help? Yea i guess its possible it did a little bit. Though now (without i guess tuning for it) the computer thinks the temps are too low? and i get a code saying the voltage is too low or something..its annoying and my fuel mileage is beginning to suck)..no idea if this has anything to do with it, or maybe the sensor just went bad for real and i need to change it..not sure..
oo and they days i couldnt break 14.2 was hot and humid as hell. Now that 14.2, 13.9 and 13.8 were run on a much much cooler day..around 75 degrees in florida
thats what i account my lower numbers for, but i guess the iat relocation didnt hurt.
The reason i did it was because my stock iat was reading 61 degrees celcius..
Last edited by LoudmouthSS; Dec 20, 2006 at 11:17 AM. Reason: Automerged Doublepost
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
"Inverse MAT Lookup Delta Multiplier"
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
helped my car.... and why is everyone's answer on th TPI message board...
"why don't you try burning your own proms?" the average joe is going to be so lost in that crap.... there is no major hp in prom burning for TPI's.... it's a bunch of
U sound burned or jealous you were unable to benefit from it.
Its like building a new IAT table when you relocate it, it can be done, but to do it truly right, it will take consdierable time and effort, but it will be right.
I have made some very good gains in horsepower, mileage and driveability over factory tuning. If you know how it all works and how it all relates to the other, its quite simple. Like anything else it has a learning curve.
I frequently tell people to investigate prom tuning because $$$ for $$$ it is one of the best mods u can do and then u can accomodate most tuning needs yourself. Its also easier to leanr the more stock the vehicle is.
later
Jeremy
I did the IAT relocation mod to my MAF-equipped TPI engines a zillion years ago when nobody built a ready-made kit. I won't say the car ran any faster, but it was more consistent from run to run and cold vs. hot. I don't know why that would be the case, but I found it to be true. On a speed-denisty motor I can imagine there would be greater benefits since the air temp has got to factor into the ECM's air density equations somehow.
I also didn't like the fact that sucker would read at "bake some muffins" temperatures after a hot restart and not really go back down to sanity very quickly. Actually, that was the reason I ever even tried relocating it in the first place.
Car: 86 Omni GLHT
Axle/Gears: 3:85
Anybody that truly understands how an engine works and has taken the time to leanr how to tune can blow your arguement out of the water easily.
I frequently tell people to investigate prom tuning because $$$ for $$$ it is one of the best mods u can do and then u can accommodate most tuning needs yourself. Its also easier to leanr the more stock the vehicle is.
later
Jeremy
later
Jeremy
Car: Faster
Engine: Than
Transmission: You!
Ok, I may be a little off here, but if you have the MAT in the plenum and have the PROM tuned to where the BLM's are very stable and the overall A/F ratio is on the money across the RPM range, then would there still be any benefit to moving the MAT/IAT to the air lid? Sounds to me like a bunch of work/time in table manipulation just to get back what you alreadly had (provided the tune was optimal to begin with when it was in the plenum).
Car: 1983 G20 Chevy
Transmission: 4L60
86White_T/A305
Sep 21, 2015 05:28 PM
air, gens, harness, iat, intake, kit, mat, mod, modthirdgen, relocation, resistor, sensor, temp, temperature, tta
