BEST HEADS FOR A FULL STOCK 305
Old Dec 21, 2006 | 09:12 PM
craziechevy's Avatar
i have 1991 z28 stock 305 ,and was woundering where i should start at i was thinking some heads, intake, roller rockers,lifters, about all the gutts inside so if can help i would really be thankfull
Old Dec 21, 2006 | 10:40 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
start with general tune up. plugs, wires, coil, k&n etc. Then move onto exhaust. Headers and a cat back will really open things up. Then you can move on to the engine.
Old Dec 21, 2006 | 10:48 PM
Car: 88 GTA
oh ya. the thread was mostly about heads. oooops. I stay with factory heads until you've done some decent modification to your engine. otherwise I doubt you'd see much gain. if any.
Old Dec 22, 2006 | 10:56 AM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
trick flow makes a set of heads specifically for smaller engines like the 305. i would go with those or get a set of LT1 heads converted for gen 1 small block use. the third option would be a set of vortec 350 heads milled to get the compression back in line.
Old Dec 22, 2006 | 11:02 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Do you have headers and exhaust yet?
Old Dec 22, 2006 | 02:47 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
do a search or see my signature, this has been covered a million times.
Old Dec 23, 2006 | 08:15 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
Look at some World 305 heads, they have prove some good HP gain, also some vortec heads milled down to 58cc.
Old Dec 23, 2006 | 09:25 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I agree with the above on the Trickflow heads. They are awesome for a 305 and not to shabby for a 350.
Old Dec 24, 2006 | 01:27 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
You want the best heads?????? Look here, if you not worried about spending about $1k on a set.... ALLPRO heads.
italiano67
Dec 11, 2016 09:21 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
