Help... missing fuel rail clip
Old Dec 21, 2006 | 09:45 PM
firehawk35's Avatar
Car: 88 GTA
Transmission: 700 R4
I hope someone can help me out here. I recently decided to clean up the topend of my motor in my 88 GTA. Well I disassembled my fuel rail to replace all the o-rings and polished the the rail. Today while reassembling the whole rail I noticed that I was missing one of the lil brackets that hold the crossover tubes into the rail. ( DAMN CAT !! ) I was hoping if anyone would know where to get a new one , or may have a extra, or would the V6 have the same pc on its fuel rail??? Im going on the hunt friday so I would be thankful for any ideas... Thanx
Old Dec 25, 2006 | 07:47 AM
Vader's Avatar
Sifted through the litter box yet?
I would think, at least in theory, that once the rails are assembled to the intake base, the supply crossover tubes would be held captive, and wouldn't absolutely require the retainer brackets. Then again, I've never tried it, and would prefer to have them all in place as an extra security measure.
Fabricating a new one wouldn't be too difficult. Find some 12 Ga. steel, and start drilling/cutting/forming.
Old Dec 25, 2006 | 09:13 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I agree with Vader....the clip on the opposite side will eleminate any movement of the tube. The tube at the other end can't go in any further and the clip on the other side stops it from coming out so you should be fine. Just put a washer on the bolt big enough to catch the lip of the tube if you want some added security.
Old Dec 25, 2006 | 11:35 AM
firehawk35's Avatar
Car: 88 GTA
thanks for the reply..Yes Vader I did check the box.. EWWWWWWW.. Well I went to the dealer and was floored. They said they could get a crossover tube kits but it would be over $100. I will try and make a lil bracket instead as I to think once bolted down It shouldnt lead but ...... I will let ya know what happens... Thanks again
Old Dec 26, 2006 | 11:28 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
You don't really need them once the rails are bolted to the intake, just be sure to release pressure before taking them apart, should do this in any case, but more so if you don't have the retainers.
I took mine off to clean & polish, ended up tossing the rail connecting tubes and all those little retainers & screws, fabricated new tubes from stainless steel, replaced and rerouted fuel lines with SS 3/8" tubing. Installed a Holley AFPR, and deleted the cold start injector.
I have a bad habit of modifying things.
Here's a pic.
if the regulator looks weird to you, it's because it's no longer angled. GM angled it to get clearance for their FPR instead of designing one to fit under the plenum.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
wayshegoes
Aug 17, 2015 12:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
