87 iroc stumbles when warm
Old Dec 21, 2006 | 10:25 PM
don87iroc's Avatar
Car: 1987 Iroc Z Camaro
Engine: 350 tpi
Axle/Gears: 3.27 Borg Warner limited slip
Hi everyone my name is Don, i'm new here i have a 87 iroc with 350 tpi with maf. runs fine when cold but after it warms up falls flat on its face with a slow rough idle. it stumbles at part throttle but at w.o.t it comes to life. it also runs fine for about 30 seconds after starting when warm and then problem persists. very confused please help!
Old Dec 22, 2006 | 09:23 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Welcome!! When it runs does your check engine light come on? Maybe take it somewhere to have it scanned. It could be something simple like the timing, or maybe some spark plugs.
Id have it scanned to see whats going on.
Old Dec 25, 2006 | 10:01 AM
irocz2173's Avatar
Car: 1987 5 speed Iroc-z
Engine: 305 TPI (not for long)
Transmission: 5 Speed
Hows your oil just a question.
Old Dec 27, 2006 | 04:18 PM
87 IROC NC's Avatar
Car: 1987 IROC-Z28
I'm getting the same problem, oil and other fluids are fine, but same problem happens.
Old Jan 13, 2007 | 04:18 PM
don87iroc's Avatar
Engine: 350 tpi
update
I figured out that my ignition module was bad because it started misfiringwhen cold and had a hard time starting. I still have hesitation but it is not as bad. I have no check engine light but i just found out I have no bulb in it so im getting a bulb and trying it to see what codes flash I will update thank you
theshackle
Sep 17, 2020 08:26 AM
Cornholio7979
Sep 20, 2018 02:31 AM
wayshegoes
Aug 17, 2015 12:00 PM
mustangman65_79
Aug 11, 2015 03:17 PM
