Install engine with TPI intake, accessories, in place or not?
Old Jan 3, 2007 | 12:56 PM
Dr G's Avatar
Hi guys,
Does anyone have any stong opinions on whether the TPI Itake should be installed on the engine when it's out of the car? Or once it's back in?
How about the distributor? Front accessories like water pump etc?
Thanks,
Old Jan 3, 2007 | 01:02 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I installed my engine (with the help of some friends) with the TPI manifold installed, along with the water pump. We left the distributor and accessories off for clearance.
Old Jan 3, 2007 | 02:27 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Aggreed, its better to put the intake on with the motor out, leave the dristibuter out, (put a rag in the hole). Everyone will agree leaning over your car is not the best feeling in the world when you do it for long periods at a time. Theres enough room in the front, so you can put ur water pump on. Thats as far as id go. You can put everything else on once the motor get put back in.
Old Jun 11, 2007 | 05:45 PM
Dr G's Avatar
Re: Install engine with TPI intake, accessories, in place or not?
Thanks for the help.
I ended up installing the intake and water pump on the engine whilst it was out, then installing the accessories, distributor, alternator etc once the engine was in. I put the headers in the engine bay and tied them to the inner wings while I lowered the engine down onto it's mounts.
Old Jun 12, 2007 | 09:06 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I thought you had that installed already.
I installed mine with no distributor, intake manny only, ALL front accessories were on.
I found, after the fact, that I could've installed my LT's from underneath the car.
Old Jun 12, 2007 | 04:20 PM
Dr G's Avatar
Vipklr, I've got the whole thing done. It was finished and back on the road properly a few weeks back. I was just going through some of my recent threads updating them where appropriate.
Is your car nearly finished yet?
Old Jun 13, 2007 | 07:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I kinda figured that when I saw that you hit one of your threads from April.
Mine's nearly finished. It's currently at the shop getting exhaust. Talk about custom. That Spohn trans x-member with DS loop and LT's is causing numerous problems with my exhaust. It's looking like i'm going to have to go H-pipe instead of the X that I have. Once I get it back I have to hook up my wideband and start tuning. So I guess i'm nearly finished but still have a long way to go.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
