Best Cam for this setup?
I'll be doing a heads/cam/intake swap on my '90 355 L98. I was thinking of the GMPP Fast Burn heads with a Weiand Vortech HSR. I want to be able to lay down 300rwhp. (I am doing the rear, suspension, and a t56 swap.)
Which cam will go good with this intake/head combo? (I don't think the lt4 hotcam would even put me at 300, but not sure.)
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The Hot Cam can easily do it. You will need the other supporting mods such as good heads, exhaust and intake system. I'm doing more than 300rwhp with less cam.
However I think there are better cams on the market these days. The lift your heads can take will be part of the determining factor. Remember lift is your friend.
Street Lethal
Apr 30, 2019 12:14 PM
