What can I expect -engine buildup-
Old Jan 7, 2007 | 10:44 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
http://store.summitracing.com/partde...ew=1&N=700+150
How well would this work on my stock bottom end 350 with flattops, 1 5/8 hedman longtubes, TPiS bigmout base, ported plenum and runners. I want to keep the TPI setup.
I'm up to 14 hours of searching and all I've come up with is that I either need to start asking questions or search even more.
Old Jan 7, 2007 | 02:02 PM
Drac0nic's Avatar
For starters, the chambers are way too big, esp. with an aluminum head. I'd be looking for something with a 58cc chamber in your shoes if it's a stock L98 short block, at least in aluminum. Either that or if you're intending to put a blower on those would probably work ok, but even so I'd probably go down to 64cc If you're looking to budget ~2K for a set of heads, you should be able to have your pick of a lot of heads. I definitley don't think I'd wanna use those unless I had some serious siamesing done to the runners and/or base, I'd stick with 180cc runners or thereabouts.
Old Jan 8, 2007 | 05:24 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Almost stock bottom end. I have Mahle flattops.
Summit won't substitute parts in the kit so I guess I'm going to have to piece something together.
So 58cc aluminum heads with flattops? Wouldn't my compression skyrocket?
Why 180cc runners as opposed to 190 or 195?
ZZ3Astro
Aug 13, 2019 12:57 AM
86z89iroc
Oct 5, 2015 01:04 PM
hartsmike
Oct 2, 2015 07:11 AM
80smetalfan
Sep 22, 2015 02:55 PM
BWilcox
Sep 20, 2015 12:19 PM
