tpi convert ???
Old Jan 14, 2007 | 12:50 PM
mattyl's Avatar
Car: 89 camaro rs
tpi convert ???
Hey guys i need some help. I have a 89 camaro that was tbi, i have a 350 carb motor in it and it will not tune. I`ve had 3 carbs and countless hours into this induction. Well i have had it .I`m looking at efi. i think holley is junk and the rest is expensive. So now i`m thinking TPI. My combo is 355 ,vortec heads,268 extreme cam,1.6 rockers,headman shorties. Will tpi work well with this combo.What hp would i see? If so which type would you recomend MAP or Mass air. Either is available all over. anything would help.. MATT
Old Jan 15, 2007 | 11:54 AM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
That setup is going to want more air than a stock TPI system can provide. I would advise something like the Holley StealthRam intake or maybe a converted LT1 intake. Either way you can use the TPI electronics, and with a couple of nifty little gadgets from Moates.net you can tune it real-time through a laptop. Tuning is a little more touchy with a MAP system, but that's still the system I would recommend. MAF systems depend too heavily on a single sensor, and if it ever goes out the MAF is expensive to replace.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Sanjay
Aug 12, 2015 03:41 PM
