Looking To Build TPI, Help Picking A Block
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I’m looking to start building a 91 TPI, 377, roller cam, 4bolt. Id like some help picking out a block to base from.
From my findings, not all camaro 350’s were 4bolts, the truck ones depend on the rest of the truck options. I know between 86/87 they switched to centerbolt heads. I’m guessing I want that option. Now, the main one. I read that somewhere in there, gm did start putting roller engines in the trucks in 96/97. Did they ever offer that on a camaro engine? To early for a vette engine I guess?
Am I assuming right that for the application I am wanting to base off of, I’m needing a truck block, and then try to hunt down some L98 centerbolt heads.
Any other good choices for me to look for?
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I think the best ones are the late Vortex truck blocks with 4 bolt mains. Dyno Don managed to snag one for my latest build up. I think he paid $200 for it. Nice looking block.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
A 377 can be gotten either way.
Concerning the block, personally, I prefer to start with new stuff, so I would buy a ZZ4 block to start your project. ZZ4 blocks are 4 bolt mains, are drilled for the ECM sensors, and are direct replacement block for the common 2 bolt L98 blocks.
Engine: 350 S-TPI
Car: '87 IROCZ
Engine: 395 ZZ4
Thats fine, find a seasoned Corvette block from '87 to ??, I think these are 4 bolt main blocks. Please check if these blocks are truely 4 bolt mains. This block would make a great fundation for your project and cost less than a new block.
Engine: 350 S-TPI
There was an 86 vette L98 on ebay when I made the post. It was only a 2bolt main.
I'm finding varying info on which L98's were/werent 4bolt, so yes I will require whoever to do a visual verification. I'm also being told the vortec heads flow much better then the alumn L98's. Not sure which way to sway there.
Thanks for all the info, I know which blocks I can look for now.
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
No L-98 350's were 4-bolt mains. You need to get a 3/4 ton or heaver truck to get a 4 bolt main roller block. I am not sure if the 96 to 99 vortec truck engines are 4-bolt main.
The other option is to have the 2-bolt main converted to a 4-bolt main or just use the 2-bolt main block. A 2-bolt main block can put up with 500 HP.
Sanjay
Aug 12, 2015 03:41 PM
