85 TPI problems , going crazy
Old Jan 16, 2007 | 06:33 AM
tripingeorge3's Avatar
I just bought my first tpi camaro. had everything else but i could never get my hands on a tpi. the car sat for over a year with gas in it. car starts if i keep hitting the gas , then eventually it will idle stumbling at first then its ok.just check the dervice engine codes got 15,33 not sure exactly what they are. i did the tune-up, oil change. i had had it running for 2 hours straight, but still after running it wont start up unless i hold the pedal to the floor, then rev it as it stumbles to get it to idle itself again. i have no clue about tpi being that its my first one and i can't rest until i figure it. if anybody has any clue whats going on please let me know. also if i take out a spark its completly wet with fuel.
Old Jan 16, 2007 | 10:17 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Check your fuel pressure, But it sounds like you have a leaky fuel injector....or more then one.
I had the same problem with mine. Plus it was blowing black smoke out the exhaust. I had 5 bad injectors. They were just dumping in the fuel.
Old Feb 3, 2007 | 11:12 AM
25AnnZ28's Avatar
How do you check the fuel injectors?
Old Feb 3, 2007 | 11:33 PM
seymourless's Avatar
i want to know this answer also. i have white smoke coming out the exhaust always at start up and under heavy acceleration. can u fuel pressure test determine if a injector is bad?
Old Feb 4, 2007 | 02:04 AM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
White smoke... you sure you dont have a blown headgasket and youre burning coolant off? Extra fuel makes black smoke. Oil makes blue smoke, coolant makes white smoke.
Old Feb 4, 2007 | 07:54 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
bad coolant temp sensor making the car run pig rich? Common tpi problem...
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
