CAN A BAD CTS CAUSE FLOODING,HARD RESTART??
Old Jan 17, 2007 | 02:38 PM
tripingeorge3's Avatar
UNPLUGGED CTS AND STARTED CAR RAN LIKE CRAP BUT IT STARTED BACK UP WITH EASE. PLUGGED IN I HAVE TO START IMMEDIATLEY AFTER SHUTTING OFF. IF I WAIT MORE THAN 10 SECONDS I HAVE TO HOLD THE PEDAL TO THE FLOOR(WHEN CTS IS HOOKED UP. ALSO HAVE CODE 33. CAN THIS BE BECAUSE OF THE CTS(CODE 15)READING TOO LOW?
Old Jan 17, 2007 | 07:58 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Yes it can, It tells the ecm what temperture it is, Ecm looks at the fuel/temp table and says 31 degreees ok this much fuel, BUT i believe if you unhook it or it go's bad its -65 So, Itll make it flood and run rich but i believe they can fail the other way
Old Jan 17, 2007 | 08:05 PM
Damon's Avatar
Oh, sure. My 91 TBI Blazer flat out wouldn't start if you had the CTS unplugged on a warm day (reading dead-cold: -40F). It would give a little kick and then immediately flood out.
Old Jan 18, 2007 | 12:30 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Yeah, I had a CTS go out on me while driving 45 mph. Started running like absolute crap, I could see the clouds of white smoke in the rear view mirror. Engine didnt respond to throttle at all, and it was making the whole car shake. After about 10 second of this crap it stalled and wouldn't restart.
I watched the injectors while cranking and they would go wide open, one or two cranks and the whole throttle body was filled up with fuel like a bowl and over flowing onto the intake manifold. Scary.
Old Jan 18, 2007 | 12:22 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
When my roc was running this pass summer, It would start cold very well. But I had problems were it would be hard to start after running say 5-10 minutes. Would the CTS also affect this issue or is it something else?
Old Jan 18, 2007 | 07:19 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i'm not sure if my problem is related but i am curious if it is. and if not any ideas would be great.
i have a 1986 trans am, TPI Fuel injected 305 5.0 engine
its my third car and in project mode. it has improved grealty sicne i purchased it 6months ago.
but for the life of me i cannot get it to stay running on the first try.
i turn it on and first time its stutters and stalls withn 5-10 seconds like its gasping for fuel or air.
i can immediately turn it a second time and it turns right on and stays on and idles around 900-1000. i have to set my idle but any ideas maybe same problem you got? or bad fuel reglator fuel pump? im not quite sure because once it stays on the second time it runs great. jsut curious if its a sign of soemthing really wrong.
Old Jan 19, 2007 | 07:49 AM
90'C/K 355 TPI's Avatar
Car: 1990 Silverado
Engine: 355 TPI
Transmission: T-56 6 Speed
Axle/Gears: 4.10
Possibly your cold start (9th injector in the middle of driver's side of plenum)
is not working. it may be electrical connection, or plugged/faulty injector.
Check for voltage at cold start injector when cranking it from dead cold.
Old Jan 19, 2007 | 11:04 AM
Bobby_80s's Avatar
Axle/Gears: no idea
does the cold start injector do anythign during normal engine operation once the engine is started and driving for a while or is it connected to shut off and let the rest of the injectors do the work?
ill check the voltage but also going to be puting some serious serious cleaning stuff in the fuel once spring comes designed to eat and clean anything built up or plugged up in the engine. the stp stuff didnt really do it for me.
worst case senario i'll pay the 300 to replace all my injectors which one will happen anyway.
thanks for the suggestion ill get right on it.
Old May 12, 2007 | 01:45 AM
88trans_am_gta's Avatar
Car: '88 gta
Engine: 350 tpi
Re: CAN A BAD CTS CAUSE FLOODING,HARD RESTART??
bringing back a old thread, i know. currently, im having the same problem with my car. it threw a code 14, and i replaced the coolant temp sensor in the front of the engine. that didnt help. took it to a mechanic and he says its either a injector stuck open flooding, or the cold start injector is junk.
on start up cold, you have to hold the accelarator down. once it fires up, it smells like someone dumped a gallon of gas in the passenger compartment. when the engine is warm, its basically the same thing, although it only happens once in a while.
probably shouldnt have to say this, but be careful with throwing fuel injector cleaner in the gas tank. some are so aggresive that it'll eat the terne in the gastank.
Old May 12, 2007 | 02:17 AM
Bobby_80s's Avatar
Axle/Gears: no idea
is the CTS its on part or is it built into the ecm? and if not where the heck is it besides that connector on the passenger side of the engine bay?
Old May 12, 2007 | 08:18 AM
Car: '88 gta
Engine: 350 tpi
i believe theres one in the passenger side of the cylinder head, one in the front of the block on the intake manifold.
Old May 12, 2007 | 02:20 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
the cts is in the front of the intake manifold, under the Thermostat housing, easy to spot
specialized
Jun 18, 2022 09:26 AM
Cornholio7979
Sep 20, 2018 02:31 AM
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
