wierd sound!!..tuck tuck tuck
Old Jan 20, 2007 | 01:34 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
whats up guys....Last night i my car developed this wierd sound and I checked again this morning, and its still there. It sound like "tuck tuck tuck tuck tuck"
. The more i reve the engine the faster the tuck gets. It sounds the loudest when I put my ear near the intak manifold on the pass side. Moving the distributor a bit changes the tone and the rate, but its still there...any ideas?/please dont tell me its bad
Old Jan 20, 2007 | 01:42 PM
Gramps's Avatar
Car: 87 Camaro IROC
could be bad, mayb a thrown rod bearing, hows your oil press? lower than normal?
Old Jan 20, 2007 | 02:05 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
oil pressure looks normal. same its always been. what are some tips so that I could diagnose this problem.
Old Jan 20, 2007 | 08:47 PM
CrazyHawaiian's Avatar
Car: too many ...
It could be alot of things, bearing, lifter, valve, list goes on. But its definately something mechanical with the engine, so I would start off by doing a compression/leakdown test. I would also manually rotate the crank while watching the rockers on both sides and following the firing order, if one of the cylinder dosn't get any lift when its supposed to that could indicate broken valvetrain.
Old Jan 22, 2007 | 08:31 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
I pulled off the valve covers and let the engine idle. everyhting looked good. all the rockers, pushrods, and springs were operating. I the tuck tuck tuck sound is still there. The sound is loudest when my ear is near center of the intake manifold - although i cant say 100% that its where the sound is really from.
I noticed another thing. Now it wont even go into drive or reverse. Its doing that loud sound and just revs without any gears engaging. I checked the shift linkage and its doing its job, but nothing enagages.
any ideas what to check next??
Old Jan 22, 2007 | 08:54 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Check your vavle lash.
My dads car was making a loud BANG on low RPM on the passenger side, it got worse as the rpm went higher.
We pulled the vavle cover and one of the rocker nuts had come loose.
Check that out, a simple fix, from what seems like a Bad proble,
Old Jan 22, 2007 | 09:23 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
If you suddenly have a noise and suddenly the transmssion wont shift, I'd say it isnt a coincidence and the sound is coming from the transmission.
Old Jan 22, 2007 | 09:39 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
sheldon - definitely not the rocker nut. the valvetrain is in tact.
toehead - good point. - i had someone else listen to it, although its loud when my ear is near the middle of the intake manifold, its a bit louder at the bottom of the car.
My buddy said it may be the torque convertor flexplate deal. Something could be broken there. Im gonna take that plastic shroud thats between the engine and the tranny off tommorrw , and hopefully ill see something there.
u guys think that might be it.
give me hope i just hope its not internally from the engine.
Old Jan 23, 2007 | 06:32 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
torque convertor bolts coming loose will produce some weird noises. couple that with the fact that suddenly your car won't move when paced in gear
Old Jan 23, 2007 | 12:35 PM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
It probably is a transmission or torque converter issue, but if not it could be an exhaust leak at the manifold or header gasket. That will make an annoying tick that sounds like a valvetrain problem.
Old Jan 23, 2007 | 02:24 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
this sound is definitely louder than an exhaust leak - ill let you guys know as soon as i get off work and take it apart.
Old Jan 26, 2007 | 01:44 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
my 305 was doing this too. sounded like valvetrain. problem got worse, and then i noticed metal in the oil. in a month or so, ill put it out, and try to find what caused it. im thinking a cracked piston or rings, cause it was smoking heavily. im currently putting my 350 together so that i can live up to my name.
Old Jan 27, 2007 | 04:18 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I was playing with a late 90"s mustang on I95 doing about 100 plus and when i got off i noticed that my car was making a loud noise and i started to freak but when i opened the hood i knew where it was coming from ,it was my smog pump it wasnt hooked up and the bearing went out and it was loud as hell so i just pulled it off and got a shorter belt now its fine but sometimes you have to look at things that you wouldnt normaly look at,oh and yes i spanked the 4.6 junk
Old Jan 27, 2007 | 07:48 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Sounds like a bad TC or a bad thrust bearing. It holds the crank in place and prevents the transmission from pushing it foward. If the thrust bearing is bad it will sound like hell and it there's enough play in it you wouldn't be able to take it out of park while it's running. Can't you put it in D/R with the engine off? Does the engine have high mileage?
Old Jan 27, 2007 | 11:35 PM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
Without much doubt it was loose bolts on the flexplate and finally 'broke' loose.
Old Jan 28, 2007 | 10:57 AM
87zjeff's Avatar
what thrust bearing and how is the trany supposed to push the crankshaft forward
there is no thrust bearing between the motor and transmission. there is a pilot bearing for manual units but it is for support of the tranny input shaft and not for thrust.
the thing that keeps the crakshaft from moving is the main bearing caps in the motor. the tranny doesn't effect this at all. the only bearings that might possibly affect if it goes into reverse,drive, or park is inside the transmission. one of those would have to be real bad to affect that.
Old Jan 28, 2007 | 12:19 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Hes most likely refering to the thurst bearing/surface on the crank shaft that prevents the crank from walking back and forth.
Old Jan 28, 2007 | 12:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
just a shot in the dark here, but i had a similar problem when one of my air tubes that came off the manifold broke. it sounded like a lawn mower
Old Jan 28, 2007 | 02:14 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Thrust bearing is the 5th/rear main bearing of the engine block. If this is shot the transmission will have problems engaging like a loose TC would. This would also explain the noise over the intake.
Old Jan 29, 2007 | 01:29 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
I pulle doff the inspection cover, and the TC and flexplate deal are in tact, and the bolts are secure. When i rotate it they both turn together. However, when I start the car, and go put my ear near the TC it definetly sounds like its coming from inside of it. I dropped the pan, and there wasnt any abnormal metal in the pan. If the i did bust the inside of the TC what are the chances that my tranny is still good??.
I currently have i on a lift ill keep u guys posted.
Old Jan 29, 2007 | 07:16 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
time for a converter upgrade
Old Jan 29, 2007 | 08:30 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
mines an 87 with the 700r4. If im not mistaken its a 30 spline 12 inch converter - is this correct??.
Also - how can i tell if the tranny is bad also???... do i have to swap the converter, and test it, or can I check while the tranny is out. There isnt any abnormal metal shavings in the tranny pan
Old Jan 29, 2007 | 11:32 AM
Car: 89 formula 350
bring the trans to a trans shop that has a trans dyno. They can tell you if the trans is good or needs a rebuild.
Old Jan 29, 2007 | 11:46 AM
87zjeff's Avatar
there are other main bearing caps and that thrust bearing wouldn't cause enough endplay to effect the tc that much. the transmission couldn't push it forward like you suggest.with one piece rear seals, the crank doesn't even have a flange to engage a thrust bearing like you suggest.
Old Jan 29, 2007 | 10:04 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Then why is there a thrust bearing?
Old Jan 30, 2007 | 03:08 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
ok. unbolted the TC and pushed it back. I started the car, and it still has the sound. I figured it wasnt enough, so i completely removed the tranny, and started the car. The damn sound is still there. Definitely something internal on the engine. Im not sure why the car wasnt kicking in gear either. I noticed the tv cable was not even in the tranny. It was just hanging. I dont know if it was like that, or it came off during the removing of the tranny. Right now im looking into replacing the motor or getting rid of the car. I dont know if i wanna dump a shitload of money into this car right now.
Old Jan 30, 2007 | 04:53 AM
87zjeff's Avatar
the rear main bering is designed the way it is to prevent the crank from walking backwards. i'm not saying a main bearing cap isn't his issue. just that it doesn't effect the tranny as you suggest. if the bearing cap was that bad, seems to me that the timing gear would be chewing through the front cover.
Old Jan 30, 2007 | 10:58 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Sorry for your luck I'm sure we've all been there. God knows I have. Every problem is an opportunity- here's your chance to go through that car and make that sucker a champ. It can be done fairly cheap if you are thrifty. Nothing beats having a good car with ZERO miles on the motor. Good luck
Old Jan 30, 2007 | 01:27 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
I would like to be thrifty, but at the same time put in something nice. If i do it it will obviously be a 350. Can someone point me in the right direction of a good deal????. All i need is the block and the heads. I need something that will retain my original intake, and exhaust manifolds.
Old Jan 30, 2007 | 05:14 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I'm not sure about Cali but here in TX I bought a reman 350 short block from a dealer for $500. Everything else can be swapped over from a 305. That would at very least get you going.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
89bird2.8
Sep 25, 2015 09:21 AM
