smog pump
Old Jan 21, 2007 | 04:23 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
smog pump
When i put on my headers and new exhaust i removed all the smog stuff but i left the smog pump because the belt was new but now my smog pump has a really loud knocking noise and i was wondering if my knock sensor is pulling out timing because of it and does anyone know the serial number of the belt needed to put on once i remove the smog pump but keep the a/c?thanx
Old Jan 21, 2007 | 10:42 AM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Once your car goes into closed loop, the smog pump ceases to function. It only operates in open loop. I took mine off my 94' z28 and went to emissions and passed. Its also off my IROC too. It cleans up the engine bay and is a little less weight as well.
Old Jan 21, 2007 | 01:10 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
The belt is a Dayco 968K6. It is 98.6 inch belt. I removed my pump last weekend and this belt fit perfectly.
Old Jan 21, 2007 | 04:32 PM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
I was refering more to the loud knocking noise that its making do to the fact that the bearings are going out and the knock sensor is hearing it and pulling out timing...............
Old Jan 21, 2007 | 05:38 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Its still gonna pump air even though you took everything off. You better off pulling it off and getting one of those air pump delete puleys that allow you to use the stock belt.
http://www.moderndaymuscle.com/inc/sdetail/773
Old Jan 21, 2007 | 06:02 PM
firstfirebird's Avatar
I just used a different belt and deleted it...
Old Jan 22, 2007 | 05:00 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
still waiting for an answer on if it is causeing the knock sensor to pull out timing
Old Jan 22, 2007 | 05:15 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
As I understand it, knock sensors dont hear knock like human ears do, they work on harmonics.
Knock sensors detect harmonics inside the block that are beyond the range of human hearing.
Old Jan 22, 2007 | 08:47 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Your not going to know if its pulling out timing unitl you hook it up to some sort of scan tool and check to see what the knock sensor is doing.
Old Jan 22, 2007 | 02:29 PM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
i agree but anything that makes a loud knocking noise will produce vibrations that the ks should pick up
Old Jan 22, 2007 | 07:24 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Only if its in the harmonic frequency range, again, as I understand it.
You couldnt bang on the side of the block with a wrench and expect the knock sensor to think its knocking, because its a different frequency range than what the knock sensor is made to detect.
Old Jan 22, 2007 | 07:29 PM
Just like the LS1 specific high ratio rockers that won't set off the KS.
ws6gta89, what's stopping you from by-passing the smog pump all together? I mean my belt was only like $27 or something. Could be sneaky and return the belt in exchange for the delete size, lol.
Old Jan 23, 2007 | 03:22 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
I have a baby due soon so i have been busy with so many things that i just havent had time for anything else i will get to it this week because i start another job next week so i have to do it now or i will never have a chance because between the two of them i will work 7 days and any free itme will be spent with my new son
Old Jan 23, 2007 | 08:10 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
https://www.thirdgen.org/serpentine
Old Jan 24, 2007 | 03:04 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
dont you mean its 96.8 inches long?
Old Jan 24, 2007 | 03:29 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Yeah man, my bad!
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
