TPI Airfilter Housing
Old Jan 21, 2007 | 06:21 AM
tyson__91's Avatar
Car: 91Z 99Z 68 SS
Im curious at what HP levels does the stock black aircleaner housing start becoming a restriction in air and HP. Cause right now with the motor in my sig when you crack open that 1000 cfm TB you can feel that box and the rubber intake hose suck in. With it doing that my motor turns about 7000 im sure its not getting all the air it wants. Also where can you get smooth bellows for a Speed density TPI intake.
Old Jan 21, 2007 | 11:57 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Potentially your engine wants more air then your stock air filter assembly will allow in, lucky for you, you have a speed density system.
Check this out:
http://www.jegs.com/webapp/wcs/store...46165_-1_11175
Old Jan 21, 2007 | 12:06 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Have you removed the baffles which are positioned below the 2 airfilters? To see what I mean, remove the air box & airfilters and look down into the square opens. Remove the small screws to remove the plastic baffles.
Also, have you been using high flow air filters?
Next, go to intakehoses.com, and you should find the correct reducer to go between the air box and the TB. BTW: a 4.0" ID rubber tube should fit over the TB.
Next, you can go on the wild side, and cut out the round end of the air box & body filler in a 3.0" or 3.5" OD alumninum tube. I would buy a second air box to experiment with to do this mod. Then buy the correct reducer to go between the new aluminum tube & the TB.
Old Jan 21, 2007 | 01:34 PM
tyson__91's Avatar
Car: 91Z 99Z 68 SS
Yeah i took out the baffles a long time ago and have been running K/N's. Im wanting to weld me up a CAI but just havent had time to do it yet. Thanks guys.
Old Jan 21, 2007 | 04:47 PM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
Dont just put a k/n filter on the tb that works but it draws in hot air you dont want that make a good cold air and you will be fine i ran mine down behind the foglight it pulls cold air and stays out of harms way(water)
Old Jan 27, 2007 | 04:46 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I dont know what hp numbers its starts to become a restriction. But on my setup, The stocker wasnt cutting it. I did the things doc is talking about and i got a nice power boost from it. I havent any numbers yet to back that up. Ive been working on other things lately. But i consider it one of those must do mods on a highly modified setup like yours.
Do a search on the TPI board under my user name. I tried to document the whole thing as i went. http://www.thirdgen.org/techboard/tp...ied-there.html
Jeremys87
Jul 14, 2022 09:08 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
