is this a good 5.0 street motor?
Old Jan 22, 2007 | 10:17 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
im doing a budjet rebuild, and so far i have a complete rebuild kit from federal muegal picked out, with aluminum speed pro pistons (8.7.1 c.p with 64cc)
and hooker shorty headers,march pullies, and a comp compu cam with , Hydraulic Roller Tappet, Advertised Duration 262/264, Lift .450/.480, Chevy, 305/350... stock heads rebuilt,,, maybe vortecs after a few months
im guessign ill need to flsh or "burn" a chip for the mods, and im thinkin of 24 injectors and a 58mm throttle.
anything else? any tips? would lt4 hotcam be a wiser choice? or should i tone down my cam choice already? anything i havent listed remains stock,,,, i might need a new crank due to spun bearing? suggestions to stoker?
Old Jan 22, 2007 | 10:28 PM
Car: 91 formula ws6
maybe i should buy rebuilt vortec heads first? i found some for 500 canadian,, and they were on a boat for only 50 hours
but do vortec heads change anything? maybe header choices? or pully set up? i know about intake already,, easy to fix with bottom plenum
Old Jan 22, 2007 | 10:33 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Vortec heads are a good cheap choice. Just make sure the springs can handle the lift of the cam you choose.
Old Jan 22, 2007 | 10:36 PM
Car: 91 formula ws6
ive heard vortecs can handle 470? but i dont know if that means stock springs or what? cuz the cam im getting comes with springs,, so everything SHOULD be compatible... unless it bottoms out the heads? do i have to mill them or something dumb? all this talk about high lift makes me want to keep stock cam
Old Jan 22, 2007 | 11:14 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
you'll need a vortec compatible intake... your stock intake will not bolt up to vortec heads.
you will also need votec headers/manifolds for the stockers or normal thirdgen headers will not work.
Old Jan 22, 2007 | 11:26 PM
Car: 91 formula ws6
what about bolt placment for accesory drive? is it easy to find vortec headers for an f body? what the max lift ishould use with my stock heads and upgraded srpings?
what about bolt placemnt for the accesory drive? and can i find vortec headers for an f body? besides no flow? why nto use stock heads with upgraded springs?
Last edited by Pennocks91ws6; Jan 22, 2007 at 11:27 PM. Reason: Automerged Doublepost
Old Jan 23, 2007 | 11:54 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
you may be disapointed wiht it a bit . You dropped your compression a bit .
Old Jan 25, 2007 | 03:37 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Ummmm.... theres no difference between vortec heads on the exhaust side then any other SBC head... you should be fine with regular old SBC round tube headers.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Wvcamaro
Sep 4, 2015 08:38 PM
Reborn756
Sep 4, 2015 03:42 AM
Street Lethal
Aug 13, 2015 08:28 PM
