Leaking Injectors
Old Jan 27, 2007 | 11:12 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Leaking Injectors
Is it possible for injectors to read the proper Resistance on an Ohmmeter an still leak? I'm thinking that is possible because just because the coil is still intact doesn't mean the jets (I'm not sure if that’s the right name) are seating properly when not firing.
I would appreciate your thoughts.
Old Jan 27, 2007 | 11:23 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
yes.
the seats can leak because of dirt, wear or damage, anything from a very slow drip to solid steady stream.
Old Jan 27, 2007 | 11:46 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Thanks, that’s what I thought. Ever since I replaced my fuel pump with a Walbro my car has been running extremely rich and will not hold fuel pressure and sometimes is hard to start because of fuel in the cylinder preventing the crank to turn unless I'm careful to turn the ignition switch on an off until it clears up.
I'm not driving my right now but I'm going to replace the injectors in a few days.
Thanks again for the reply.
jklein337
Sep 19, 2018 06:23 PM
92projectcamaro
Jan 18, 2016 08:00 AM
BAMiller
Sep 14, 2015 06:38 PM
greenyone
Sep 2, 2015 03:39 PM
