350 TPI
Old Jan 23, 2007 | 06:51 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
350 TPI
Getting a deal for a complete 350TPI with harness and computer for 550.00, blown head gasket, it does run and can even drive the car.It's in a 88 firebird, ...........now the ????
what would I be able to do with the stock heads if there still good, I know I can put a LT1 cam in and will most likely get the kit with lifters. I have aset of headers for it now and plan on 3in exhaust
right now I have a 89 305TBI IROC, that runs great, just really can't pass this up.
will I gain much by porting the heads or should I look at replacing.
Not looking at huge HP just more respectable than the 170hp from the 305TBI
I will not drag the car so weight savings is not an issue, this will be a summer cruiser only.....most 300hp
One more question what about the fuel pump???? should I get from the 350??
Old Jan 26, 2007 | 10:12 PM
djtricia's Avatar
Car: 1986 Z-28
Take the heads from the 305 and put then on the 350 for increased compression. Porting them won't hurt either. I don't know about the fuel pump though. Bt the way is this motor coming from a guy in Mattawan?
Old Jan 26, 2007 | 10:27 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Good god, don't put those swirl-port 305 TBI junk heads on the 350... Stick with the 083 castings that are on it...
You will need to replace the in-tank fuel pump that is in your car with the TPI pump (which has higher output pressure)...
As for the wiring harness, if you can get the entire engine harness from the donor car, that might not be so bad, but keep in mind that it isn't that bad to do the TBI->SD TPI wiring harness conversion thats on this site. I have performed it myself on a TBI-to-LT1 intake swap conversion.. Works great and easier (in my opinion) than swapping the harness.
I don't think that the LT1 cam is actually much different than the stock L98 cam... Might want to check before bothering to swap it out...
Old Jan 27, 2007 | 05:16 AM
gscz28's Avatar
Car: 89 iroc
yea it is in mattawan, I've gotten quit a few parts from him in the past nice guy to deal with.
No I'm not going to put the 305 heads on this engine, that never entered my mind,
are you sure the stock cam is an L98?
or does anyone have the spec's for the stock cam to compare to an LT1?
Yes I am getting the complete harness and computer
thanks for the reply
Old Jan 27, 2007 | 07:59 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Was the car with an automatic tranny?
If so the cam is:
Int/Exh 179/194 Lift .350/.384
If manual tranny:
Int/Exh 207/213 Lift .415/.430
LT1 Cam (F-body verson, be sure to make sure you have this one)
Int/Exh 202/208 Lift .450/.460
Old Jan 27, 2007 | 01:23 PM
thirdgen88's Avatar
Car: 1995 Corvette
If so the cam is:
If manual tranny:
The motor he has is a 350 TPI... == L98... If its an 88, and a 350, then it didn't come with that cam. Go here to see the specs of stock cams for an '88.. Or, if you're too lazy, it should be this cam:
Model Number - 10066049
Duration at 0.050" - 207/213
Lift (1.5 ratio) - .415/.430
Lope Sep. Angle - 117deg
Notes - 88-89 350,305
Old Jan 27, 2007 | 01:37 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
And sheldon it couldnt have the l98 w/ a manual tranny unless it was a swap.
Old Jan 27, 2007 | 02:09 PM
gscz28's Avatar
Car: 89 iroc
thirdgen88: who has that cam, I've looked in Jegs' Summit, and Yearone..
the closest I can find is in Yearone (206/210 and 450/480)
the engine is out of an 88 formula auto I think
Old Jan 27, 2007 | 02:21 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Ah, your right
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
