Bigmouth and AS&M
Old Jan 31, 2007 | 11:00 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Bigmouth and AS&M
Are the bigmouth base and AS&M runners already port matched?
Old Jan 31, 2007 | 06:53 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I would be interested in knowing that too as that's the setup I want to run in my 92 GTA.
Old Jan 31, 2007 | 08:38 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Not likely. However what you want is the AS&M runners to be slightly smaller in diameter than the BigMouth intake. If they are larger then that will be a problem and needs to be corrected. It would be hard to have them exactly the same size and line up on all four ports when bolted on.
Old Jan 31, 2007 | 08:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
NO... The ASM runners are larger then the TPIS/Edelbock base
Old Jan 31, 2007 | 10:51 PM
Car: 1989 GTA
Engine: 369 TPI
Then you will have to open up the runner side of the base.
Old Feb 1, 2007 | 07:15 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Crap.
My85TA
Aftermarket Product Review
Sep 2, 2002 07:22 PM
poncho9789
Sep 16, 2001 10:49 PM
Beefy89
Apr 24, 2001 11:42 AM
Daz
Sep 14, 2000 07:58 PM
