tank pressure?
Old Feb 7, 2007 | 08:11 PM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
tank pressure?
While in stop and go traffic my fuel tank builds up excessive pressure. When I open the cap I can hear it relieve. While this happens my car tries to die on accelration. Today it shut off and wouldn't start until i let it sit for 5 minutes. What do you guys think?
Old Feb 8, 2007 | 07:47 PM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Do you still have your evap canister? Passenger side of engine compartment up front. If so, maybe it has a problem.
Easy fix would be to go to the Autozone or whatever and get a vented gas cap, as the stock one doesn't have a vent.
-Nick.
Old Feb 10, 2007 | 08:04 PM
my-roc's Avatar
Car: 1987 Camaro IROC Z-28
Engine: 305 T.P.I.
Transmission: 700 R4
i am having the same problem with my 87 350 5.7 ltr. tank pressure builds up and pushes gas out the vacuum cannister vent line. I get a code 36 engine light which reads as M.A.F. sensor faulty. I started a MAF thread and got lots of good info. It might help you out. Check out my-roc and you'll find the thread. I still have the problem and am keeping my gas cap loose. I hadn't thought to get a pressure relief gas cap yet. I still need to fix the problem though. Any info will help. thanks Aaron
83 Crossfire TA
Jan 3, 2016 01:26 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
Strick1
Sep 4, 2015 07:11 AM
