head/cam setup
Old Feb 12, 2007 | 10:41 AM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
head/cam setup
i have a 88 formula with the 5.7 tpi question is what head/cam setup shoul i use for street use and occasionl track?
Old Feb 12, 2007 | 02:47 PM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
vortec heads ,edelbrock lower intake,Lt1 hot cam(525"with 1.6rr) along with exhaust and intake mods with a 2500 stall and atleast a 3.23, 3.42 and up would be better but no lower than 3.23 along with a shift kit should be mid 13"s all day on street tires
Old Feb 12, 2007 | 09:13 PM
smithtc's Avatar
mid 13s
...Is that all?
Old Feb 12, 2007 | 09:38 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
i would hope at least a high 12 with a stall, heads, cam, intake base, and a full exhaust/intake with street tires
Old Feb 12, 2007 | 10:32 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
i agree that setup would be sweet! i have most of that on my 383 and the lt1 hot cam with the 1.6 rockers are sweeeeeet!!! i went with world sportsman II heads.
Old Feb 13, 2007 | 03:01 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
I would hope for 12's also but there are alot of things can keep you from running consistant 12's like elevation,track prep,tires,driver,etc..... but 13's should be a easy to do no matter what,sorry if i was misleading
Old Feb 13, 2007 | 04:45 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Ya Heck,, I just ran a 14.10 on a completely stock motor without headers or trans mods. I would hope that he'd run high 12's!
Old Feb 13, 2007 | 03:34 PM
Axle/Gears: 4.10
if i was to run with that setup, would i have to do any tuning, or would stock tune be ok? should i just get a chip for it?
Old Feb 13, 2007 | 03:42 PM
Axle/Gears: 4.10
ok, im looking around for those parts, and beeing a noob to the tpi could you posibly shoot me some part numbers or links? i dont want to order the wrong stuff. also will the heads work with the tpi>
Old Feb 13, 2007 | 06:42 PM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
The heads will not work with a stock lower intake thats why i said to get a new one and from what i have read on here edelbrock is one of the only companies to make them now.I dont have any part numbers but you could check there web site or even ebay for the intake and try searching the junkyards for a low mileage set of heads and have them checked and bowl blended and a little port work and you will be very pleased with your results and most people wont even be able to tell your motor isnt stock.You can get the cam set from GM and it will come with everything you need.Along with all that you should get long tube headers,exhaust,[find one that fits the sound your going for]cold air,and you might not need a tune to get it running but it is always the right thing to do for the best performance and driveabilty of the car,there no point in building a car if doesnt meet all of your goals take your time and do it proper the first time and you will save money in the long run.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
