Car cuts off when put into gear
Old Feb 12, 2007 | 06:44 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
This just started today and i have not changed much at all. When I put the car in reverse to pull out of the garage it cut off, then I start it back up and try it again and the same thing. The only way I can get out of my garage is to give it gas while I'm putting it in gear. This doesnt happen when I'm going from park to drive, only from park to reverse. Could this be my fuel pump going south or an electrical sensor issue. By the way, this is an 87 305 TPI motor with minimal mods.
Old Feb 12, 2007 | 08:34 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
t
Old Feb 12, 2007 | 10:30 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
let it warm up a bit...maybe...ummm try adjusting your idle up alittle??
Old Feb 12, 2007 | 10:41 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
I had that same problem ; check for vacuum leaks and faulty egr valve. It resolved after I corrected these problems.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
MENINBLK
Aug 5, 2015 11:58 PM
