1.6 3/8?roller rockers stock L98
Old Feb 15, 2007 | 11:50 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
Will a set of 1.6 roller rockers work witht he stock springs? im gonan be doing valve stem seals and figured I might as well upgrade.
Also what rockers would I need? Obviously self algining but are they the 3/8ths ones? Also if i should need new springs what do u recomend?
thanks
Old Feb 16, 2007 | 12:37 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Stock would be 3/8's and everyone has their own opinion on what ones are best. How many miles are on this motor? I would strongly suggest looking at another set of new springs and changing those out at the same time as your seals. You will be amazed at how well your motor will run with a fresh set of springs. Look for ones compatable with how much lift your cam is going to make with the 1.6 rockers on. Hope this helps a little.
Old Feb 16, 2007 | 06:53 AM
wannafbody's Avatar
Car: 88 GTA
the engine has 140K on it but it has excelent compresion so im not gonan tear it down just yet. What is the lift of the stock cam?
Old Feb 16, 2007 | 08:11 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
.404/.415 203/207 114.5. you dont need to tear down the motor to replace the springs. and with that many miles on your motor it would do some good.
Old Feb 16, 2007 | 12:02 PM
wannafbody's Avatar
Car: 88 GTA
I was told by someone that I might have to machine the heads so the pushrods will clear? is this true? never heard of that.
Old Feb 16, 2007 | 03:15 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
no, not at all. get comp cams 981 springs. there a drop in replacement spring.and they easly handle the lift with the 1.6RR. http://store.summitracing.com/egnsea...s=false&N=+115
are you fimilar with changing your spring?
Old Feb 16, 2007 | 05:37 PM
wannafbody's Avatar
Car: 88 GTA
no not on a car, I have done a few 4stroke atvs. Looks pretty simple though. i just gotta find the tools.
79malbiu's Avatar
im buying 981's will the stock studs pull out with a .500 lift roller cam
Old Feb 16, 2007 | 05:40 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
no, they'll be fine. if you add anymore lift i would get them, but you should be fine with that.
Old Feb 17, 2007 | 03:37 AM
wannafbody's Avatar
Car: 88 GTA
Do you know witch stem seals I should use? maybe a part number?
Any type of rockers better than others? any suggestions?
and last Will the stock valve covers fit?
thanks this fourm is a life saver.
Old Feb 17, 2007 | 12:01 PM
wannafbody's Avatar
Car: 88 GTA
and one more thing, will the stock pushrods be ok?
Old Feb 18, 2007 | 11:58 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
yes the push rods will be fine as your vavle covers. i dont know the part # for the vavle seals. you could do a engine seach on summit's site. any RR will be ok as long as there self alining.
Old Feb 18, 2007 | 01:42 PM
wannafbody's Avatar
Car: 88 GTA
Awsome, thanks alot does anyone know if the stock valve covers are aluminum or steel? And should I get new retainers and shims?? Man i never new there was so much stuff just with valve springs
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
