Part #'s for ford injectors
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Sorry..yes i've searched and just still confused. Just need to make sure. I need a full set of injectors for a 350TPI. New GM ones are so pricey. I Hear people using the Ford SVO (ie. ford motorsports) with satisfaction. I have an AFPR. What size would be best for an otherwise stock 350tpi without having to mess with the PROM. Oh and I need part #'s.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Simply go onto the Summit Racing site. You want the Ford Racing 24#/hr injectors with the EV1 connector. You have a choice between a match set (alot more money) or a standard set. I could give you the part number, but my Ford Racing catalog is MIA.
Start with 43psi fuel pressure and see how the car runs, change as necessary.
edit: In my Summit Racing catalog, part # is: FMS-M-9593-A302....
Thanks a bunch for the clarification!
BTW What exactly is a 'matched' set?
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
A matched set is a set of injectors (in this case 8) which are flow matched. In other words, the company would be flow testing hundreds of injectors and from the flow test result, group the injectors in sets of 8 whereby the flow of each injector are very close.
Obviously, the flow matched ones seem a better choice. But I am shy on cash and am wondering if there would really be any problems with the non-matched set.
