Quick TB bypass Question
Old Feb 20, 2007 | 08:08 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Hello all, I was just wondering if it is proper procedure to drain the coolant from the radiator before doing the bypass modification? Thanks
Old Feb 20, 2007 | 08:12 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
that shouldn't be neccessary
Old Feb 20, 2007 | 08:20 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
No coolant should come out maybe just a little. Just take radiator cap off to relieve preesure incase there is any
Old Feb 20, 2007 | 08:22 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
I thought I would have too. Simply because the lines are below the top of the radiator fluid level so gravity would simply push the coolant out of the lines??? Or is it only when the engine is running that the coolant is circulating?
Old Feb 20, 2007 | 08:37 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
when I did mine I lost perhaps 3 cups of coolant in all. Just have a catch can at the ready or put some towles down.
Old Feb 20, 2007 | 09:29 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Any other input appreciated
Old Feb 20, 2007 | 09:47 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Coolant should come out at minimal because the thermostat is closed and coolant that spills is trapped in the manifold. Therefore the coolant will not start rushing out as thought because line is lower then radiator hose
Old Feb 20, 2007 | 09:58 PM
thirdgenSS's Avatar
my dad and i just did this mod two weeks ago and i barely lost any coolant at all like just a couple drops and caught them with a cap to a spray can
Old Feb 20, 2007 | 10:57 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Thanks guys
stalkier
Dec 6, 2015 11:25 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
