Lt4 hot cam ?
Old Feb 27, 2007 | 12:28 AM
house's Avatar
Car: 1988 Iroc Z
Transmission: coan racing 700r4 coan 2500 stall
Axle/Gears: 9 bolt with 3.27's
Lt4 hot cam ?
can a Lt4 hot cam be put in a tpi motor with stock heads? if not whats a good roller cam that has a decent lope to it and compatible with stock heads for a while to the budget allows afr's
the goals for it are afrs, and stealth ram or lt4 intake
Old Feb 27, 2007 | 01:01 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need a cam with .470 lift or less. The largest one that fits is the Crane Compucam 2032, at 214/220 and .460 lift. However, plan on replacing the stock valve springs and valve seals at the same time, as you dont want to trust your new camshaft to 20 year old stuff.
Old Feb 27, 2007 | 09:04 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
thats the cam I installed in my 305. My car runs and sounds great. Its a nice cam for sure.
I'm pretty sure it was Kevin that told me to go with that cam last year. And YES.....very good choice!
Heres the link to it.
http://www.cranecams.com/?show=brows...tType=camshaft
f-bodyz28
Sep 2, 2015 05:03 PM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
