intake and cam ;)
Old Feb 16, 2007 | 04:40 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
intake and cam ;)
i've added a few things: AS&M runners( ive ported the stock base and pinlum to match) and a crane Z cam (218/230 .459/.486 112LSA). ill admite that its big for a stock headed TPI but it sounds GREAT. tell me what you guys think.
btw it has a stock chip in it that will be replaced with a custum one.
> http://s178.photobucket.com/albums/w...t=100_2765.flv <
Old Feb 16, 2007 | 04:45 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
here's a pic
Old Feb 16, 2007 | 08:58 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
sounds really good!!
Old Feb 17, 2007 | 03:09 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Sounds good!!!!
Your stock heads are killing your power potential.
Old Feb 17, 2007 | 04:42 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
DId you use a older block with the tpi on it or you put a flat tappet in place of a roller?i have a 447" flat tappet and it has a slight lobe to it and i want to upgrade and the guy that did my motor said he has a 480"lift cam that would work great .What exhaust do you have?
Old Feb 17, 2007 | 06:12 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
thanks for the compliments.
it actually has a stock exhaust with headers and no cat. a cat-back will be one of the next mods. the stock head are going to find there way out when i can afford some 180 AFRs and maybe a 383 stroker kit. ill probably get the base extrude honed. it is a factory flat tappet motor. 85L98.
hey nighthawk how much hp sould i be pulling with this?
Old Feb 17, 2007 | 07:04 AM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
sounds killer, thats the excat idle I want, what is you idle rpm?
Old Feb 17, 2007 | 01:53 PM
coynamy's Avatar
Car: 1996 Ford F-150 4x4 and 1989 T/A
Engine: 302 in Ford,305 TPI in T/A
Transmission: automatics in both
Axle/Gears: not sure,just got T/A
That's the idle I want too,what's the part # on that Crane Cam you used?
Old Feb 18, 2007 | 05:43 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
Wow that sounds really good for a stock exhaust!!!!!
Im not trying to be an *** but there is no such thing as a stock L98 in 85 you might want to do some research on what motor you really have because if it is a 350 then its not the stock motor and if its the "stock" motor then it is a 305.
Old Feb 18, 2007 | 12:07 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
it is... it came out of a 85 corvette. it might not be an L98, but it is a 350. i check it when we put it in.
here's the cam http://store.summitracing.com/partde...2&autoview=sku
the idle is with the stock chip. it idles around 700 rpms, but it surges a little when its cold. it needs a new choke.
Old Feb 18, 2007 | 12:27 PM
coynamy's Avatar
Thanks alot,that idle sounds awesome,I even saved that clip to my email.
Old Feb 18, 2007 | 07:15 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
if you have a SD tpi then it wont idle at all with the stock chip. i have the MAF. and thats a flat tepped cam.
Old Feb 19, 2007 | 03:26 AM
coynamy's Avatar
I've got the maf,so I should be good.
Old Feb 20, 2007 | 04:27 PM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Transmission: Turbo 350
Axle/Gears: 308's
FWIW, My 85 Vette is a factory stock 350, aka L98
Your's sounds nice!
Old Feb 21, 2007 | 10:53 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
holy cow stock exhaust ??? Sounds like a borla !
Old Feb 21, 2007 | 01:54 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
correction of errors!
i talked to my dad, and he said he did put a flow master muffler in it but he dosent remember what kind of flowmaster it was
any who ill be getting a cat-back soon!! what kind do you guys think i should get? are if i should just leave it alone?
Old Feb 21, 2007 | 03:51 PM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
I kinda like it as is.
Old Feb 21, 2007 | 04:53 PM
coynamy's Avatar
As good as it sounds,I'd leave it alone,like I said,I saved it to my emal and listen to it all the time.Can't wait to have mine sounding like that.
Old Feb 22, 2007 | 03:07 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
I meant there was never a l98 or any type of 350 in a 85 f-body,sorry
Old Feb 22, 2007 | 07:09 AM
wannafbody's Avatar
Car: 88 GTA
agreed you could run a 3" pipe from the y back though
Old Feb 22, 2007 | 07:24 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
it does. i found that out when it got the Y-pipe made for it.
its all good ws6gta89, but you are right, there were none for the Fbody. i just pulled the old switcharoo when the 305 spun a rod.
Old Feb 26, 2007 | 08:29 PM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
Looks good man! Sounds really nice to boot. I had better get to finishing my car up to stem the tide of jealousy I'm feeling right now
It's nice to see that the runners really do look stock. Here in CA my car gets the smogging equivalent of a night in prison as "the pretty guy", so the more stock-appearing the better.
Post up when it's tuned. Nice work!
K
Old Feb 26, 2007 | 08:48 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
That sounds killer!!!! If it was mine I consider leaving it like that. If you add a cat back the tone may change alittle.
It does sound alot like a Borla, mayh be you should think about getting a Borla cat back, might keep the same tone.
That sound is making me consider keeping my ZZ9 cam I got.
Old Feb 27, 2007 | 09:40 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Dayum. Sounds good.
I wonder how mine'll sound with full lenth headers, true dual 3" and my cam that's 224/230 .566/.570 112lsa.
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
hayesaw0210
Aug 23, 2015 11:15 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
