tpi wiring harrnesses the same
Old Feb 28, 2007 | 07:19 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
are all tpi computer wiring harrnesses the same?? i know that 1985 is probibly different and in 1990 they went to speed dencity. but is 1986 to 1989 the same? i got an87 gta and am putting an 89 350 in it. i got the engine from an 89 iroc-z and the computer but not the wiring harness. the wiring harness is in good shape in the gta but will it hook up? for your input
Old Feb 28, 2007 | 07:40 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
you should have no problems if your car and the donor car both have the cold start injector setup. MAF sensor harnesses should be the same.
Old Mar 7, 2007 | 04:21 PM
Axle/Gears: YEP
what if the motor your putting in dont have a cold start injector and the cars original setup did??
Old Mar 7, 2007 | 06:29 PM
Tubbed's Avatar
Then you would need to reprogram your computer I believe. Are you keeping the 9th or losing it?
Old Mar 7, 2007 | 10:43 PM
Axle/Gears: YEP
loosing it.
Old Mar 8, 2007 | 09:08 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Does your '87 GTA have VATS? I don't think they do, so you can swap in the '89 Camaro 350 and computer. Reuse your existing harness and just leave the plug for the 9th injector sitting there.
Old Mar 8, 2007 | 09:11 AM
Axle/Gears: YEP
thats what i was going to do but felt i should ask first
Old Mar 9, 2007 | 09:15 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
ugg.
Use your existing and functionally working harness. Does the '87 have a motor in it right now?
-- Joe
Old Mar 9, 2007 | 06:47 PM
Axle/Gears: YEP
yeah, but i was looking at the harness the other day and it dont look right. there are only like 3 wires coming off the passangers side injector harness. the drivers side got like 8 or so wires. i might just put in this 5.0l tbi motor out of my running (right now, cause i need to get to work) camaro. I'de hate to do that to this great conditioned gta with low low miles(54k) but i want it to run. would this even work??
Caspar
Jun 19, 2016 11:19 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
