Throttle Body Bypass
Old Mar 4, 2007 | 01:29 PM
Dave Farr's Avatar
Ever since putting a TPI/Vortec into my 89 truck I've never had the engine coolant return thru the TB due to too lazy to put a new gasket kit in, and also had the heater hose coming out of the Stewart water pump-old style. I know there are advantages to keeping the charge air as cool as possible, but living in Canada poses some other winter conditions- I haven't had any problems so far but as time goes on I find myself moving closer to stock configurations to limit divability problems. As I understand it- icing problems would happen around -5 to +5 deg C (around freezing) but deep winter dry conditions shouldn't have an affect either. Should I return the plumbing to factory. I'm putting back the 195 thermo from a 180 as well.
Old Mar 5, 2007 | 05:19 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
If you aren't worried about the couple of extra HP and it sounds like you aren't you should hook it up.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
