Low on power now...
Old Mar 12, 2007 | 09:25 PM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
Low on power now...
Alright I've had an exhaust leak at the passenger side manifold for a while now. I finally fixed it and in order to get the manifold off I had to remove the A.I.R tubes, the spark plug wires, and that black "thing" that has three of the A.I.R hoses and two electrical connections on it. Well now that I put everything back together, the leak was fixed, but now it runs weak. The idle is alittle lower and surges quite a bit. When I accelarete I can't even break the tires loose and it takes a while to shift, but when it shifts it shifts really firm, better then before. The car used to run strong, what do you think happened?
Old Mar 12, 2007 | 10:07 PM
B-Holly's Avatar
Your computer might need to adjust itself again since you do not have that leak anymore.
Not really sure, im still learning the old OBD1 since i bought mine.
Old Mar 13, 2007 | 12:41 AM
Car: 1985 Z/28
Engine: L98 Carbed
It seems like my gas nileage went down also and I can smell gas a little stronger then before. Well I checked the timing just to be sure and its a 6* btdc. How long does it usually take for the ecm to adjust?
Old Mar 13, 2007 | 07:14 AM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
go back under your hood and make sure that you didnt accidentally disconnect any wires/vacuum hoses....
Old Mar 13, 2007 | 12:34 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Specially the line going to your Fuel pressure regulator.
Also make sure you didnt crack any lines.
Did you disconnect your battery when you fixed your leak?
Old Mar 13, 2007 | 03:53 PM
Car: 1985 Z/28
Engine: L98 Carbed
I didn't disconnect the battery, was I suppose to? Man its running really rich its guzzling gas like theres no tommorow and the smell can almost knock me out. I'm gonna check all the vaccum lines right now when I go outside. Its idling better though. In drive it idles at 500rpm really stable.
Old Mar 13, 2007 | 06:56 PM
Car: 1985 Z/28
Engine: L98 Carbed
I'M FREAKING RETARDED!!! I found out what is was. When I put the spark plug cables back on I switched the 6 and 8. I can't belive it ran as good as it did with those cables switched. I could have swore I checked it. Maybe it was cuz I was tired that I overlooked it.
Old Mar 13, 2007 | 10:03 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Hey mistakes happen. Just be glad you found out what it was. Glad it was nothing serious.
Old Mar 14, 2007 | 07:20 PM
Engine: 364ci LS2
Axle/Gears: 3.46
so is it still running really rich?
Old Mar 14, 2007 | 10:08 PM
Car: 1985 Z/28
Engine: L98 Carbed
Well its running like it was before, which i think is still a little on the rich side. What would cause it to run rich?
theshackle
Sep 17, 2020 08:26 AM
soarestransam
Sep 1, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
novaderrik
Aug 10, 2015 12:44 PM
