TPI star bolts
Old Mar 15, 2007 | 12:29 PM
miamivice's Avatar
Car: 88 GTA
TPI star bolts
alright, quick question.
can i get a new set of these bolts from GM? ...or anywhere for that matter?
one of the star bolts that connects the runners to the plenum is pretty stripped out and i am completely missing another one. although there is no leak i would most definitely like to have that bolt in. help!
thanks guys!
Old Mar 15, 2007 | 12:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Torx bolts? You could get new ones from a dealer, or any nut and bolt supplier. You don't have to stay with torx heads if you don't want to, an allen socket head would work, too.
Old Mar 15, 2007 | 01:34 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I think they sell a complete kit on Ebay thats all stainless steel.
I was going to get one just to dress up my motor a little bit.
Old Mar 15, 2007 | 01:51 PM
Abubaca's Avatar
Ugh, TORX suck!!!!! ....I replaced EVERY single one on my motor. But yeah, they should be easy to find.
....For the TPI, I used stainless allen bolts. I honestly can't remember where I got 'em from, but it was a kit.
Old Mar 15, 2007 | 03:13 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
http://www.mmsacc-stainless.com/
Fair prices on shipping and very good prices on the hardware you need. Even some custom aluminum hold downs and brackets.
Old Mar 18, 2007 | 11:41 AM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
TPiS has an 81 peice bolt kit for TPI. Polished SS button head allen bolts.
Old Mar 18, 2007 | 12:01 PM
Gramps's Avatar
Car: 87 Camaro IROC
you shouldnt be buying stainless bolts for an engine that has to heat up and cool down all the time. stainless is just about the most UNstable metal, and will just break under certian conditions. going to your local bolt store wont work either unless you custom order some grade 10.9 bolts. going to the dealer is the best bet because they will order the correct bolts, correct length, and itll only take a day or 2. your bolt store may take a week, and they probably order the wrong stuff because theyve never seen grade 10.9 (metric grade) with a standard thread.
Old Mar 18, 2007 | 01:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's nothing special about the grade of the factory intake bolts, and they see little stress, thermal or otherwise. Replacing them with stainless is fine.
Bolts that are stressed, like rod bolts, head bolts, etc. you'll never find in garden-variety stainless.
Old Mar 18, 2007 | 05:13 PM
Car: 86 T/A
Engine: HSR 355
The ones I bought were either grade 8 or higher. Should be enough to keep together an intake and manifold.
Old Mar 18, 2007 | 07:03 PM
87_Injected's Avatar
Car: 2010 2LT RS
I tried getting these bolts from the dealer for my 87 vette and was told they have been discontinued. So these bolts are the same for the 3rd Gens as well.
Old Mar 18, 2007 | 09:06 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
www.tpiparts.net sell them.
Old Mar 19, 2007 | 12:40 AM
Gramps's Avatar
Car: 87 Camaro IROC
if the dealership said that they you ask for another guy because he probably used to work at the nissan dealership :P
and if you decide to use stainless, make sure to either coat the threads with gear oil, or anti-sieze (copper is preferred for its thermal properties). the diss-similar metals will bond together from the heat, and without protection, will corrode and fuse together. same goes for aluminum heads and steel bolts.
evilstuie
Jan 9, 2020 08:29 PM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
