Plenum extension cover bolt size?
Old Mar 27, 2007 | 06:04 PM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
What size bolts do I need for the plenum extension cover/distributor cover? I bought a cover without the hardware, just in case your wondering why I can't match up the stock bolts. I know they are small metric bolts. I tried a few different sizes and did a couple different searches with no luck.
TIA, Nick.
Old Mar 28, 2007 | 10:22 PM
MARO-MAN's Avatar
Re: Plenum extension cover bolt size?
Nobody knows the answer to my question? Maybe I have to go to GM??
Old Mar 28, 2007 | 10:36 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Well I bought a tap to chase the threads on mine. Went to look for the tap and the only one I could find around that size was 4mm x 070. The reason I did not post before was that I was not a 100% sure. Seeing as no one else is speaking up I went and posted anyways.
By the way you can by the screws at www.tpiparts.net The plastic cover uses a screw with a bigger head that has a washer shape. The metal one that came on the Corvette uses a standard head. Hope this has been of some help to you.
Old Mar 29, 2007 | 04:03 AM
iroc88lb9's Avatar
if it helps,there the exact same size as the screws used to hold the TB plate to the throttle body.
this is what i used on my 88 iroc when i bought the alum vette cover,GM dealership couldnt figure out what size they were.
Old Mar 29, 2007 | 11:32 AM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
The screws for the corvette cover, you gan buy from GM for like 7 bucks a shot.... waste of money. I still havnt gotten around to finding screws for mine
Old Mar 29, 2007 | 10:21 PM
iroc88lb9's Avatar
as i said earlier...the screws that hold the tpi plate on the throttle body,are a perfect match for the vette extension.
Old Mar 30, 2007 | 10:49 PM
MARO-MAN's Avatar
Thanks for the tips guys. I will be taking one of my TPI plate screws and find some screws hopefully. -Nick.
Old Jan 1, 2016 | 10:22 AM
SOCAL-Z's Avatar
Car: 87' IROC
Glad I found this 9 year old thread. I just ordered a aluminum TPI distributor cover and need to buy the screws for it.
Old Jan 1, 2016 | 12:23 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
BOLT. Intake & Exhaust Manifold
BOLT,INT MANIF PLNM EXTN(M4X.7). Required: 03
For: F 5.0F(LB9) (1985-1992) (1990 - 1992).
$9.42 14083852
Old Jan 2, 2016 | 06:56 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If you're going to the hardware store to get them, the plenum extension screws are M4 x 0.7, 10mm long, Button head Torx with a funky captive washer.
Old Jan 2, 2016 | 07:29 PM
SOCAL-Z's Avatar
Car: 87' IROC
Thanks for the info I will get them at the bolt store by my house they have most everything.
Old Mar 24, 2016 | 09:17 AM
Huntboy7's Avatar
Hey do you have these for sale?
Old Mar 24, 2016 | 09:53 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
No, I do not. The one in the photo came off my extension.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
