Tubing flow
Old Mar 28, 2007 | 04:28 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Tubing flow
Does anybody know how many cfm a 3" round tube will flow? I was leaning towards a 4" CAI but I may go 3".
Old Mar 29, 2007 | 05:09 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Tubing flow
Nobody knows?
I just need around 700 cfm (what the engine can pull in).
Old Mar 29, 2007 | 09:20 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Tubing flow
I have a 3.5" CAI on my car. David Vizard has some formulas out but I can't find them right now. Same for the exhaust.
Just for information a K&N airfilter will flow 6.03cfm per square inch of surface area. So don't forget to figure the air filter figured into you CAI system. Also remember there is a cumulative effect. That is the total flow will be less than the lowest flowing component.
Old Mar 30, 2007 | 04:42 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Tubing flow
89GtaTA - you know my setup. Do you think 3" is going to be enough for my engine or should I go larger?
Old Mar 30, 2007 | 09:00 PM
Car: 1989 GTA
Engine: 369 TPI
Re: Tubing flow
If you can go 3 1/2" I would do it. It can't hurt anything and will be of help in the long run with additional mods.
3 1/2" is what size the LT1 elbow is. So that is what GM used.
Old Mar 31, 2007 | 12:14 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Tubing flow
Where'd you get yours?
Old Mar 31, 2007 | 12:52 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Re: Tubing flow
I've got a 3.5" CAI setup on my 91 GTA from Fbody Motorsports. I shaved 0.21 in the quarter mile just from that mod. I ordered a few pieces from http://www.intkaehoses.net to build my own CAI setup for my 92 GTA. I have to put the pieces together still just to make sure everything fits properly. I'm going to use an 88-89 TPI Firebird intake elbow and a K & N.
Old Mar 31, 2007 | 04:18 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Tubing flow
Did you just get a 4" diameter piece of silicone? How well does it fit the throttle body?
Old Mar 31, 2007 | 05:12 PM
Car: 1989 GTA
Engine: 369 TPI
Re: Tubing flow
Here is where I purchased my aluminum tubing.
http://www.globaltecheng.com/Product...terLineRadius=
Here is where I purchased the hose from the throttle body to the tube.
http://www.bakerprecision.com/
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
