Anyone running this cam?
Old Apr 1, 2007 | 09:18 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
350 – 383 CID SBC Engine with stock manifold and heads Cam #74216
213/219 duration @ .050 .493"/.502" with 1.6 rocker
Lingenfelter cam for L98/LT1's I am running a modified L98 (intake, runners, plenum TFS heads, 106rr's) and I have the motor out. It currently runs the stock cam and 1.6rr's. Fuel mileage is decent and it has a tall 2.88 gear. I'm wondering how fuel mileage will be affected over the stock cam. Should I run this cam, tune it and leave the 2.88 or keep the stock cam, tune it and install more gear. Its mostly a cruiser that I like to take on highway trips.
Old Apr 1, 2007 | 09:29 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Anyone running this cam?
What lift will your heads handle?
Old Apr 1, 2007 | 09:42 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
good cam for the TPI. i had a similar cam in my 305. wasn't bad. i liked it.
Old Apr 2, 2007 | 10:58 AM
Rob Wade's Avatar
Well heres the deal...I put the motor together last spring with the L98 cam. Now I have the motor out of the car due to a broken valve spring (inner). I ordered the heads with the small springs because I was keeping the stock cam. Now with the motor back out, I'm tossing the idea around of a cam change. Since I'm installing new springs and the heads are already cut for them I will probably upgrade. The thing is I drive this car alot on the highway and with the price of fuel nowadays I don't want to kill the decent mileage I get now. Decisions, decisions! Bigger cam and keep the 2.88 gear or more gear and keep the stock cam.......
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
355tpipickup
Aug 13, 2015 07:35 AM
