question about 1.6 rockers
Old Apr 2, 2007 | 07:45 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
whats a reasonable set of 1.6 rockers that i can get.... are there some that i can get for under 150.00 dollars..... just got my crane powermax 2032 cam.... ^_^ and i wanted to know what 1.6 rockers i can use with that cam and my car.... thanks
Old Apr 2, 2007 | 08:14 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
Re: question about 1.6 rockers
check whiteperformnce1 on e-bay. they might not be listed at the moment but shoot them an e-mail.
Old Apr 2, 2007 | 09:20 PM
ajk511's Avatar
Car: 1991 z28
only 5 transactions and they are with the same guy on the same day, all of which are "private" and the buyer is skipwhite? i wouldnt buy from that guy, sounds like he's padding his feedback.
Old Apr 3, 2007 | 12:41 AM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
try looking at summit, they have alot of there brand stuff for real cheap prices
http://store.summitracing.com/partde...6&autoview=sku
go to that link, summit 1.6 ratio roller rockers for 149.99, i think that fits your bill!
Old Apr 3, 2007 | 09:01 AM
iroc88lb9's Avatar
those posted above wont work,you'll need the self aligning rocker arms.
Old Apr 3, 2007 | 11:59 AM
i bought the summit self aligners last year for my car they were $279.00 if i remember right. it turned out that the heads on my reman. motor didn't need them though, go figure. i kept them anyway figured i could use them on pretty much any combo i wanted to run down the road. if you don't need to run self aligners i found these:http://cgi.ebay.com/ebaymotors/SBC-C...mZ260103965766
Old Apr 4, 2007 | 07:24 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
skipwhite not whiteperformance. Whiteperformance1 is his shop. He does only sell non SA. I got a set of 1.6 ss rr from him for $100. Talk about beefy rockers.
BTW - his feedback is over 12200.
Old Apr 4, 2007 | 02:37 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
CNC Motor sports sells a nice set of self aligning 1.6 rockers, I got them for close to 150, made an offer and they took it. There are a set of stamped roller tip rockers floating around that are self aligning, I believe comp makes them.
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
