305 with rod knock...
Old Apr 2, 2007 | 09:29 PM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
My 305 just developed some rod knock. I have a 350 that I am going to rebuild for it. The heads I have are these:
462624.....75-86...350......76cc chamber, 1.94/1.5 valves
I can't afford to buy any other heads. I have a few questions. Can I reuse all of my old TPI stuff? And what cam will yield the most power without having to tune my computer? Any input will help...
Old Apr 3, 2007 | 06:39 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Re: 305 with rod knock...
Yes your TPI stuff will work just fine, you will have to change some sensors that are for a 350 not 305.
As far as the cam, is the block set up for a roller cam?? anyway I would not go over .488 lift with press in rocker studs.
good luck
Old Apr 3, 2007 | 07:40 PM
Car: 1985 Z/28
Engine: L98 Carbed
No it is not a roller... What sensors would I need to replace? And will a hot cam throw off my computer?
Old Apr 3, 2007 | 07:48 PM
joejoe's Avatar
Car: red one
Injectors, Knock sensor, EST module, the ECM prom needs to be for the 350 The ZZ4 hotcam is a roller cam (I think)
Old Apr 3, 2007 | 08:23 PM
Car: 1985 Z/28
Engine: L98 Carbed
I did some searching but what I need to know is since my car is an 85, would I have to order the esc and knock sensor from a 85 corvette? and the prom where would I get that?
Old Apr 3, 2007 | 09:55 PM
joejoe's Avatar
Car: red one
You can get everything you need at ....TPIparts.net
Reborn756
Sep 4, 2015 03:42 AM
Thaney9
Aug 29, 2015 03:16 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
