Urgent Help Please!!!! Problem installing TPI base on ZZ4 engine.
Old Apr 8, 2007 | 08:55 PM
Dr G's Avatar
Guys,
I need some help/advice. I'm literally in the middle of installing my new ZZ4 GM Crate engine with the Aluminium L98 heads. When I try to install the standard GM TPI manifold base the front and rear bolts line up and install fine. But the pair of bolts in the centre on both sides seem to be 3-4mm out.
I've tried torquing the others down to the proper specs but it doesn't solve the problem. I'm using the correct gasket thickness and not using excessive sealant etc.
Any advice would be much appreciated. From my searching I haven't found any problems like this with ZZ4 and the stock base.
Thanks.
Old Apr 8, 2007 | 09:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Urgent Help Please!!!! Problem installing TPI base on ZZ4 engine.
Is it that they don't line up, or is the angle of the two center bolts different?
Old Apr 8, 2007 | 09:12 PM
Dr G's Avatar
That's correct Apeiron, they just don't line up. I was thinking I might need to drill the holes in the intake manifold a bit larger possibly?
I'm in garage with the car, engine and laptop at the moment.
Old Apr 8, 2007 | 09:20 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Those heads use the early bolt pattern, not '87 & up.
Old Apr 9, 2007 | 04:13 AM
Dr G's Avatar
Dyno Don, are you sure? Summit and GM say the heads are 87-91 Corvette Aluminum L98 heads.
http://store.summitracing.com/partde...9&autoview=sku
Old Apr 9, 2007 | 08:18 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Wasn't the D port design in the later years? You might be able to tell that way ???
Old Apr 9, 2007 | 09:15 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
the zz4 heads use the earlier bolt pattern same as the aluminum L98 heads
Old Apr 9, 2007 | 10:17 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
you should beable to elongate the intake holes with no problem.
Old Apr 9, 2007 | 04:25 PM
Dr G's Avatar
Thankyou gents. I elongated the holes with a Die Grinder and a file. Washed the parts and offered them up.
From examining the intake manifold base more closely it appears to be an '87.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
