idle problem
Old Apr 15, 2007 | 11:42 PM
Kandied91z's Avatar
idle problem
i just picked up a 91 305 tpi. when i start the car the idle jumps to 1500 and then within 10-15 seconds jumps down to 1100 and remains. it's been so long since i've worked on a tpi, what controls this so i can get the idle closer to the factory 750 rpm range on startup? the car ha 170k miles so i'm assuming maybe something is bad or needs adjustment.. thanks in advance!!
Old Apr 16, 2007 | 09:37 AM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
Re: idle problem
on first start up when the engine is cold it should idle high around 1200-1300 rpm then slowly go down from there to about 750-800 alteasr mine does and it runs great.
Old Apr 16, 2007 | 11:34 AM
Guest
Guest
Posts: n/a
Re: idle problem
Might try cleaning the throttle body and IAC passages (dont take anything apart at this point though) and see if that helps.
Old Apr 16, 2007 | 01:19 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: idle problem
From what I seen, the standard seems to be 1000 rpm cold, 750 warm in park.
Old Apr 16, 2007 | 03:59 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: idle problem
have you tried resetting the IAC sensor
Old Apr 17, 2007 | 07:25 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Re: idle problem
make sure to clean your throttle plates,right behind were they shut builds a little ridge and allow extra air
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
