question about 305 swap!
Old Apr 17, 2007 | 11:08 AM
bobert's Avatar
Car: 1988 pontiac trans am
Transmission: auto
Axle/Gears: ??
im buying a 305 tpi long block from an 87 camaro to replace my 305 tpi in my 89 trans am! the long block has a bigger crank in it than my 305! is there going to be any problems when i swap them besides just needing an intake for the motor?
Old Apr 17, 2007 | 11:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: question about 305 swap!
I don't understand why you have a bigger crank stock for stock.
Why would you need a new intake? They should both work. Just swap the 1 runner to block off the CSI.
Old Apr 17, 2007 | 11:28 AM
bobert's Avatar
Transmission: auto
Axle/Gears: ??
the guy said it was a G92 option car soo it came with a 350 crank in it!
Old Apr 17, 2007 | 11:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If he told you that, then he has no idea what he's talking about.
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The G92 option is for a performance rear axle.
Old Apr 17, 2007 | 11:41 AM
bobert's Avatar
Transmission: auto
Axle/Gears: ??
soo this would have nothing to do with the engine having a bigger crank?
Old Apr 17, 2007 | 11:42 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Nope.
Old Apr 17, 2007 | 11:44 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Nothing at all. There are no "bigger cranks". The 1987 engine is going to be the same as your 1989.
Old Apr 17, 2007 | 01:03 PM
bobert's Avatar
Transmission: auto
Axle/Gears: ??
ok thank you!
Old Apr 18, 2007 | 09:52 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
only difference will be the 87 will have a multi belt system. Where your 89 was a Serpt belt set up. Also the Alternator and the A/C pump are swapped.
Crank is the same.
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
reiderz iroc
Aug 13, 2015 04:57 PM
