How big is too big for valves?
Old Apr 18, 2007 | 01:03 PM
87irocvert's Avatar
Car: 87 Iroc convertible
Transmission: t5
I am looking to put a set of aluminum heads on my 1987 TPI 305 w/T5 camaro. I have searched the boards and read on one that 2.02 valves were too big for the 305. Don't remember the reason this second. I found these:
http://cgi.ebay.com/ebaymotors/ws/eB...7439850&rd=1,1
But I don't want to over do it. I already have an opened up intake system with ported plenum, AS&M runners and ported intake base also ported throttle body and homemade ram air system, Ceramic coated Edelbrock headers, y-pipe, hi-flow cat and Edelbrock 3inch cat back system for the exhaust. Also planning better ignition system, bigger injectors and Adj. fuel pressure regulator.
Any other suggestions would be helpful as long as it isn't put in a 350. The 350 will come when the 305 dies, but it has a lot of life left in it. Plus I don't want to tear up my T5 with a modified 350.
Old Apr 18, 2007 | 01:48 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: How big is too big for valves?
There is a formula that you should not exceed 52% of the bore diameter for the intake valve. Otherewise you will run into what is called valve shrouding.
Old Apr 18, 2007 | 03:03 PM
iroc88lb9's Avatar
ditto what he said...
and 2.02 valves will contact the cyl wall in a 305,unless you notch them for clearance.
a 1.94 valve is PLENTY for a 305. i had a roller 305 block,carbed with heavily ported 416 heads with 1.94 valves,and a comp xe270 something cam...it put down 271rwhp in a 85 t5 transam,not to bad for an extreme budget build.
Old Apr 19, 2007 | 12:26 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
1.94/1.55 are as big as you could go on a 305.
Old Apr 19, 2007 | 03:33 PM
87irocvert's Avatar
Transmission: t5
Thanks guys. That's exactly what I need to know. I imagine notching the cyl walls would be a huge pain in the a$$.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
sandman92084
Sep 12, 2015 10:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
