Code 36
Old Apr 21, 2007 | 01:57 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
Code 36
this code has been haunting me for a while now.... its maf burnoff relay, and i just dont know what to do..... do you guys think the actual MAF sensor could have to do with this code or no?
Old Apr 28, 2007 | 02:43 PM
rnyost's Avatar
Car: 1989 Flame Red GTA 5spd, 89 Bright
Engine: 305tpi and 350tpi
Transmission: Auto and 5spd
Re: Code 36
It actually means what it says the relay is bad not the sensor. We had this code on our GTA and didn't find out it was the relay until after we changed the sensor and read the service manual. We changed the relay and never had a problem again. $10 from advance. I just don't remember which one it was on the firewall.
Old Apr 28, 2007 | 04:03 PM
bigchief's Avatar
Re: Code 36
i know which it is, i'll try to change it and see what happens. thanks a lot!
would any parts store sell it??
Old Nov 27, 2007 | 09:11 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
Re: Code 36
i'm having the exact same problem with my 87 iroc-z the only thing i havn't done is change the ecm or e-prom let me kno how you make out.
Old Nov 27, 2007 | 11:12 PM
bigchief's Avatar
Re: Code 36
it ended up being my ECM, i changed it and my problem was solved....... this has happened to me before though
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
