Moving the map sensor...
Old Apr 24, 2007 | 11:05 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
Hi All,
I have a 85-86 TPI Set-up that I switched to Speed Density. I don't have the mounting hole for the MAP sensor bracket in the plenum.
My question is would it hurt or change anything to mount the map sensor on the firewall? It'll be about 15"-20" from its factory location so I didn't know if that would cause a change in vacuum or incorrect readings.
Thanks in advance
Dennis
Old Apr 24, 2007 | 12:19 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Moving the map sensor...
No problem in moving it I just wouldn't move ti that far away, why not on the firewall?
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
gord327
Oct 3, 2015 01:25 PM
Fanatic1074
Oct 2, 2015 03:47 PM
aaron7
Sep 30, 2015 09:15 AM
