Edelbrock and cam choice
Old Apr 27, 2007 | 04:54 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
1988 iroc..engine is a 4 bolt main block, scat crank, pm rods, hypereutectic pistons, 383 cu in., edelbrock 60cc performer heads, edelbrock tpi system, comp cam roller rockers, comp cam, polished tall valve covers. All accessories are there except smog pump. New power steering lines, alternater, starter and battery. Engine is fromm enginefactory.com I want something that'll put me in the 400-425 rear-wheel horsepower. any suggestion or setups?
4 Bolt Main, Full Round Seal Block
New Scat CS383 Crankshaft
PM connecting rods
H860CP Hypereutectic Pistons
Sealed Power Chrome Moly Rings
Heavy Duty Double Roller Timing Set
Aluminum fast burn Edelbrock 60cc Chamber cylinder heads #60859 with stainless steel valves, hardened valve locks, chrome moly retainers & HD Valve Springs
Matching Comp Roller Camshaft
Comp Cams Hydraulic Roller Lifters
Federal Mogul Tri-Metal Bearings
New Comp Cams pushrods
Comp Cams Roller Rockers
Edelbrock Intake Base Plate and Runners Manifold #3890
Old Apr 27, 2007 | 05:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Edelbrock and cam choice
One of the bottlenecks will be the Edelbrock TPI manifold. I have mine Extruded Honed and I'm running out of air at the 350rwhp mark. To get to 400rwhp you are going to have to get the runners in the manifold opened up.
Not sure on the Edelbrock heads you have but they need to flow somewhere in the 280cfm range if not more. If you are serious I would send the heads and intake manifold off for professional porting.
Old May 2, 2007 | 04:46 PM
Car: '87 Iroc-Z
bump
Old Mar 12, 2008 | 10:34 PM
Car: '87 Iroc-Z
bump
Old Mar 12, 2008 | 11:01 PM
Car: 1989 GTA
Engine: 369 TPI
To be honest you are not going to make it with those parts. The number one thing is the heads. They don't flow enough cfm to make 400 to 425rwhp. I don't think they are a good choice for a 383.
Next up you did not state what camshaft your are running. You will need a good modern camshaft with at least 230 degrees on the intake at .050" and a lot of lift. A little bigger would not hurt.
The Edelbrock TPI intake manifold will need a lot of work to flow the numbers required for what you want to do. It can be done just money. The crux will be the runners. I don't know of any you can buy that will support that kind of horsepower. SLP's might but will require a lot of work. Your Edelbrock runners might but would also require a ton of work. The factory plenum will work with modification. Maybe a Holly Stealth Ram is in order.
I would want to use a 58mm throttle body. You will need a first class exhaust system such as Dyno Don's 1 3/4" headers, wye pipe with dual cats and a good cat back system.
Don't know what your cold air intake is like but you will need a good one depending on whether a Camaro or a Firebird.
With a 700R4 I think you will need 500hp at the motor to achieve your goal. You will need a good selection of parts and proper assembly.
Old Mar 12, 2008 | 11:21 PM
Car: '87 Iroc-Z
yeah, i've since posting this up months ago came to realize this isnt ideal, more like 425HP at the flywheel is what i am aiming for. and i want to use a LT4 hotcam in my 383 stroker. any ideas or thoughts on how i can reach that using the edelbrock intake and runner combo with a ported plenum anyone?
Old Mar 12, 2008 | 11:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
my thoughts...
Those heads are not much better than L98 aluminums but STILL can make 425hp on crank so your good IF everythign else is right
Flat top pistons and 60 cc heads = WAY too high compression... roughly 11.6 to 1. 2 options..... ditch the heads or ditch the pistons for dished. MAYBE a third option is to have the heads ported and possibly opened up to 65-67cc or so. that be more doable 10.8 to 11 to 1 compression range
hotcam MAY be enough cam for that motor with a fully siamesed/ported TPI setup to achieve 400-425 CRANK hp. I'm thinking thats roughly 330-340 at the wheels. Hotcam 383's have hit 370-380whp with GOOD heads and intakes like miniram/carb manifolds/ or HSR. Else step up to the 230/236 XE grind or CC306. That should easily put you there with those heads IF you keep compression to 10.5-11 to 1
Old Mar 13, 2008 | 10:25 AM
Car: '87 Iroc-Z
appreciate it. Thanks You
Hotrodboba400
Dec 10, 2019 07:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jorlain
Oct 8, 2015 01:57 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
