cold start injector problem
Old Mar 12, 2008 | 09:26 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i bought some slp runners for my 88 gta with the 9th cold start injector and the cold start injector line wraps around the back end of the runners but it doesn't seem to fit behind the fuel rail like its suppose to... the only way i can see it fit is if i bend the line up alittle to fit the injector line... could i bend the line to make it fit into the rail or would it break... what could i do... thanks
Old Mar 13, 2008 | 12:44 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: cold start injector problem
so long as you aren't being violent with it, you should be able to make adjustments to the line. i had to make a couple minor adjustments to the line to fit my edelbrock runners as well. in my case the right side of the runner was binding on the fuel line not allowing me to line up the bolts or injector right... a little tweaking and everything fit nicely. the paint on the line might crack a little, but the line itself is fine.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
