Suggestions for replacement injectors?
Old May 3, 2007 | 09:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
One of the injectors on my 91 Corvette is bad, and after the hassles of getting that apart, I think I want to just replace them all. It's got stock 22lb injectors on it now, but has a good amount of mods, so I'm sure it would do just fine with some 24s... but I'd prefer not to do a PROM change if I can avoid it. Will moving up to 24s make me too rich, or will I be good to go?
Anyway... what injectors do you recommend? I've got 24lb SVO injectors on the Camaro and they're noisy, but otherwise seem to work well.
Old May 3, 2007 | 04:52 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: Suggestions for replacement injectors?
As far as I know the SVO injectors are made by Bosch and work great. I've got a set in a 305 TPI.
You can pick um up cheap on ebay. Cheaper than cleaning cost.
Old May 4, 2007 | 09:48 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Pink top svo 22's will work perfect with stock chip
Old May 5, 2007 | 09:57 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Ford Racing (formily SVO) does not make 22 #/hr injectors. Buy the 24 #/hr injectors and install them along with an AFPR, run the fuel pressure at 38 to 40psi should help.
I have been running my 24s for about 10 years.
Old May 6, 2007 | 12:28 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
They make the pink top 22's. Do a little search. I believe fiveomotorsport.com or something like that sells them. Direct replacement for your worn 22's
jklein337
Sep 19, 2018 06:23 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
mizz0313
Aug 12, 2015 06:45 AM
