Compression Test this weekend
Old May 4, 2007 | 09:13 AM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Hi all,
Is this all i need to do a compression test on a TPI?
Connect Battery Charger- for equal charge over each crank
Disable fuel& Spark
Pull out all spark plugs.
4-5 Cranks
Anything 130PSI or lower bad
All should be within 10% of each other.
Old May 4, 2007 | 11:16 AM
Guest
Guest
Posts: n/a
Re: Compression Test this weekend
Open the throttle all the way.
If its relatively stock, probably will be in the 170-185 range.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
