what is the best spark plug
Old May 7, 2007 | 03:41 PM
camarojunkie's Avatar
I have a set of aluminum heads which the valves are 2.02 / 1.60 195cc
T'here going on an 350 block 4.060 (of course) I have a good steet/strip
cam which will be fuled by tpi system head gaskets will be felpro
1003. I live in the south east. would like to know what spark plug would
give me the best performance Idon't the lift numbers on the cam
Old May 7, 2007 | 03:50 PM
brutalform's Avatar
Re: what is the best spark plug
Whats the CR of the engine? Might want to start out with a cooler plug, than a hotter one. use a dab of antiseize on the threads with aluminum heads.
Old May 7, 2007 | 05:56 PM
10 1/2 -1
Old May 8, 2007 | 01:30 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I run an Autolite 3923 on a 10.5:1 355 running the AFR/LPE219/Superram combo. They are two heat ranges colder than stock.
Old May 8, 2007 | 10:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Why run colder plugs?
Old May 8, 2007 | 01:40 PM
subliminal's Avatar
NGK plugs FTW!
Old May 8, 2007 | 01:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why are you using the 1003? I use NGK FR4s with my aluminum heads.
Old May 8, 2007 | 01:46 PM
northern-tpi's Avatar
I work with a race team that runs a sprint car and all they will run is NGK. I also have a boat with twin V8's and my Mercury Marine Mechanic also swears by NGK's. They say all the other brands don't seem as reliable. If you are worried about the temperatures you can always gap differently for your application.
Old May 8, 2007 | 02:22 PM
brutalform's Avatar
I normally use a Champion RC12YC, which are a cooler plug. I would rather use a colder plug in my tuning, to begin with, as the only problem would be "fouling" if they are too cold, as compared to a hotter plug with the CR I have, and while utilizing a more aggressive spark table, in my eprom. Every car is different, but this is what I use, and do, for the correct heat range on my car.
Old May 8, 2007 | 03:28 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I like my AC Delco's. Never had any problems with them so far.
Old May 8, 2007 | 06:20 PM
iroc88lb9's Avatar
Originally Posted by subliminal
NGK plugs FTW!
agree'd!
thus far i have NEVER EVER had an issue with ngk plugs or accel cut to fit 8.8 wires....the one time i tried msd and mallory....i got bum sets....so i stick to whats tried and true.
Old May 8, 2007 | 10:58 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Never had a problem with AC Delco.
Old Jun 24, 2007 | 03:18 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I'm also running the Autolite 3923's (approx 10.5:1 383) and they seem to be too hot still for my motor. The color mark on the ground strap is about halfway between the threads on the plug and the bend in the round strap.
Does anyone have any other suggestions? The 3923's just seem like they should be perfect...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
