What or who makes this...?
Old May 9, 2007 | 03:44 PM
Stevo's Avatar
Car: Pair of 92 Z28s
So i pulled off the plenum today to install a BBK AFPR...and i found this:
Now to my knowledge a stock regulator did not have a bolt in the top correct so it could not be adjusted. Well this one does have a bolt in the top so im guessing its adjustable? Any idea who makes this, there are no markings of any sort. Im thinking its a TPiS AFPR as it looks similar to what they show on there site.
-Steve
Old May 9, 2007 | 04:03 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: What or who makes this...?
hmmm i installed the BBK one too like over a year ago but when i took my stock one off i didnt look like that, who cares lol put the BBK one on and make sure the rubber diaphram is still ok. ive seen ppl modify the stock ones thats what it could be
Old May 9, 2007 | 05:42 PM
Stevo's Avatar
Well im not gonna put on something i dont need. Adjustable is adjustable. Ive already been tinkering with the one on there and watching the fuel pressure go up on the gauge.
I do have a question for you guys, how do you possibly adjust fuel pressure when you can hardly fit an allen wrench in there when the plenum is on?
Old May 9, 2007 | 07:59 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
LOL....thats why I bought the Holley AFPR.....so I wouldnt have to worry about that.
Old May 9, 2007 | 09:00 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Maybe if you cut off part of the short end of the allen key, it will be alot easier to adjust the fuel pressure.
Old May 9, 2007 | 09:07 PM
Car: 87 TA clone
thats why u should put in the BBK, i would put it in just bc it looks better haha jk. actually the BBK one doesnt use an allen it used a hex bolt and would allow easier adjustment of the screw wit the plenum on. ur gona have fun with the allen i'll tell u that...
Old May 9, 2007 | 09:18 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
...or maybe go to the hardware store and get a short bolt to replace the Allen screw. That way you can get an open end wrench in there to adjust it.
Old May 9, 2007 | 09:51 PM
Stevo's Avatar
Haha already done guys. I trimmed the short side of the allen wrench tonight ill have to try it out on the car tommaro.
With the key on, it shoots up to 38-39 and slowly drops down. Gets down to about 10psi in a little over 5 minutes or so. At idle my gauge is telling me its at 36-37psi. If i rev it i think it hits like 46 or so. The gauge kinda fluctuates 1-2psi so its not steady enough to get a completely accurate reading. Is this normal? I test drove the car and it likes more fuel, doesnt exactly feel quicker but feels "smoother". Seems to idle a little better too.
I had datalogged my car a few days ago and it had been running lean.
Do you guys have any idea who makes this FPR?
Old May 10, 2007 | 06:58 PM
Car: 87 TA clone
hmm doesnt sound good, ur testing the fuel pressure with a gauge? where is the gauge in the car or on the fuel rail. are u setting it with the vacume line disconnected? also it should read 43psi stock but bump it to 50psi and it should stay pretty level, i used an accel gauge on the fuel rail and it was steady. if it drops down it sounds like ur fuel pump is going or shot, it should be able to maintain fuel pressure.
Old May 10, 2007 | 09:56 PM
Stevo's Avatar
Using a gauge on the rail. I left the vacuum connected.
How long should it maintain fuel pressure with it pressurized and the key removed?
Car runs fine and all just curious though.
Old May 11, 2007 | 02:05 PM
Car: 87 TA clone
the pressure should stay pretty close bc when the key is turned on it builds and when u turn it off i dont believe it releases the pressure for a few min, thats why when u turn the key on and off and u keep turning the key on the pump wont turn on for a couple min untill the pressure bleeds off, dont kno the exact time, and u need to set it with the vacume line disconnected, there is a big diff in pressure
Old May 11, 2007 | 10:48 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I bought some braided line & ran it from (what used to be) the Schrader valve to a permanent fuel-pressure gauge underhood - and I've seen it retain pressure for at least a couple weeks...
Also, I'm one of the people that's modified the stock FPR to be adjustable, & it's worked great for me for years. (Just don't see the point of spending money on something you can do for free.) My vbGarage has a link to how it's done, if anyone's curious...
Bubbajones_ya
Aug 31, 2015 12:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
Thaney9
Aug 7, 2015 08:25 PM
